Old 06-12-2016, 11:30 AM   #51
Hugeez's Avatar
Had similar issue. Have same truck. Switched to 10 ply tires (Coopers) and keep them at 80psi. I also had Air Lift helper springs installed. After some adjustment in my WDH I was also able to almost eliminate the sway in the rear of our TT. I do have a question though... With a 30' TT and the go ahead from the boss on the new truck, why would you not go with a 2500? Stiffer suspension and better tow ratings would seem like a no brainer. Unless, like us, the funds don't match the wants.
Hugeez is offline   Reply With Quote
Old 06-12-2016, 11:58 AM   #52
The funds always play a big part. I wanted. 3/4 ton but the wife threw the brakes on. Said if I got a 3/4 ton then I would want to get a bigger camper. She knows me too well 👍😜
Marty, Carla, Gabby and our ankle biters Rocky and Addy
2011 Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS
eyeguy1 is offline   Reply With Quote
Old 06-12-2016, 03:58 PM   #53
Hugeez's Avatar
I wanted a 3/4 also. Maybe our next vehicle.
Old 06-12-2016, 08:54 PM   #54
CaptnJohn's Avatar
I told my wife when we traded that I wanted a 3/4 ton truck. She said NO!!! She said that if I got a bigger truck that I would go get a bigger TT or most likely a 5er. Yep she knows me too well. Lol
BUT ~~~ that truck and a 5er wouldhave eliminated all thought of sway.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-12-2016, 09:28 PM   #55
Lol. True
Old 06-16-2016, 02:16 PM   #56
So i contacted the tire manufacturer - they reckon the tires i have on my truck currently *Michelin LTX A/S* are passenger rated tires and have a max capacity of 2068 per tire. They recommend upgrading to LT tires. Irrespective brand - is this the recommended way to go to try and eliminate some of the sway?
GeeTee is offline   Reply With Quote
Old 06-16-2016, 04:59 PM   #57
Hugeez's Avatar
Yes. I went from stock Goodyear passenger tires to Cooper light truck 10 ply tires. Inflate to mfg suggested 80psi. The sway from the back of the truck virtually disappeared and that was being transferred through the TT.
Old 06-16-2016, 08:25 PM   #58
Check your trailer tires carefully. Last week I experienced trailer fish-tailing when ever I got to 63ish mph. 148 miles into my trip, my right rear tire blew out. Put on the spare, noticed that the fish-tailing went away. My tires were at their max cold pressure just before we left and there was no visible deflation or heating when I checked them at the only rest stop we took. I suspect the tire had a weakened sidewall from what was a minor curb strike.
2013 Rockwood Signature UltraLite 8319SS
propbndr is offline   Reply With Quote
Old 06-18-2016, 11:12 AM   #59
dsjohns71's Avatar
Also the Cooper Discoverer HT Plus are not LT tires. They are XL tires. They have a load range of 119T and a reinforced sidewall.
I got them on sale for $608 vs about $1100 for LT for my truck.
My problem is the tire size of my truck. The LT tires have a limited selection. 275 60 20.
I have been well pleased with them until we got the newer truck. However. I do feel that the majority of my issue is the different suspension.
Our TT is a big winds ail going down the road. The height is 13ft 2 inches so it catches every breeze anyway.
Before I went to the equalizer WDH 4 pt sway control. I was towing down I65 and a flea sneezed on the side of the road. I thought I was going to get pushed to the median 😜
Eyeguy, I have the same truck and same hitch, (which btw for everyone else,, IT HAS A SWAY BAR, so why would you want to add another, like on those POS chain wdh's) and I added the airbags and they helped out a lot but still had that same "wiggle" so when it was time for new tires I spent a little more and got the Michelin ltx/at tires, they are E rated and 10ply. I went up in size to a 275 65 20. They made all the difference in towing. I tow a 8600 lb trailer with 980lb tw, yes this has been weighed and pulls great but pulling a tall and long trailer you'll always feel the side winds as you have lots of sidewall (basically a sail).. So while the airbags do help, you'll find the LT tires will help even more. Hope this helps some...
dsjohns71 is offline   Reply With Quote
Old 06-18-2016, 11:37 AM   #60
I installed airlift 1000 bags and ran 20lbs. We are camping now. Lol boiled about 200 miles yesterday and the bags helped a ton. I am going to look into LT tires next week though
sway, towing, truck
