Old 06-09-2016, 07:21 AM   #1
Truck Rear End Sway While Towing
Hello folks. We have a 2016 Wildwood 30kqbss which we use to tow with an older truck 2007 Dofge Ram 1500 4x4 SLT Big Horn. My wife finally said I could get a newer truck as long as the color matched our TT. Lol. Well I elected to purchase a 2011 Ram 1500 4x4 SLT Big Horn 5.7 Hemi (love my rams and Hemi)
Here lies the issue. The older ram had leaf spring and the newer Ram has coils in the rear. After taking it out 3 weeks ago I noticed that the rear of the truck actually sways. You can feel it moving sided to side.
I have readjusted the Equalizer 4 or sway WDH and it still does it.
I ordered some Air Lift air bags (#60818) and they will arrive tomorrow to see if that helps.
We have a 300 mile tow next weekend so I want to try and fix this issue
Has anyone else had this issue?
Marty, Carla, Gabby and our ankle biter Rocky
2011 Dodge Ram 1500 SLT Big Horn 4x4 Hemi 5.7
Forest River Wildwood 30KQBSS
eyeguy1 is offline   Reply With Quote
Old 06-09-2016, 07:29 AM   #2
What tires are on the TV? If they are P tires, you may want to upgrade to LT tires. It will make a difference in side to side movement.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 06-09-2016, 07:33 AM   #3
Could it have something to do with the truck tires? I installed airbags on my Silverado and while they added convenience they didn't do anything for sway as the little I have with the truck is tire movement. I don't inflate them much when towing, up to 15 psi from 10. If inflated much more than that the airbags will affect the setup of the WDH. I have the Equalizer also and it does an amazing job as far as the trailer.
Brewhedd is offline   Reply With Quote
Old 06-09-2016, 07:34 AM   #4
Good tires and Bags help the 1/2 ton Rams with Coil springs! Youroo!!
youroo is online now   Reply With Quote
Old 06-09-2016, 07:42 AM   #5
I just put cooper discoverer h/t plus tires on my 07 ram about 8 months ago and they did great with towing. I had the dealer put my coopers in the 11 ram when I bought it (they had wranglers on it)
These coopers have the reinforced side walls and did great on my other truck
I am of the opinion that it is the different rear suspension (coils instead of leaf springs)
I am hopeful that the air bags stiffen the coils since these bags mount inside the coil itself?
Old 06-09-2016, 07:43 AM   #6
Tires? Air Bags? Or it maybe time to upgrade the hitch to a Hensley.
BBQGUY is offline   Reply With Quote
Old 06-09-2016, 07:46 AM   #7
Lol on the Hensley. I had to get rid of my boat because the wife wanted a camper. I have invested a ton on her "wants." If I can fix this white knuckle pulling then "hopefully" the money flow out will stop.
Marty, Carla, Gabby and our ankle biters Rocky and Addy
Old 06-09-2016, 07:48 AM   #8
Hensley hitch will do nothing for his truck suspension.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-09-2016, 08:49 AM   #9
Restcure's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
If I read the OP correctly the issue is sway, which may or may not be symptomatic of his truck's suspension.
Whether towing with leaf or coil springs, however, the Hensley (or the Propride 3P, which I tow with) will eliminate the sway completely.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-09-2016, 08:53 AM   #10
Originally Posted by JD and Beastlet View Post
...Whether towing with leaf or coil springs, however, the Hensley (or the Propride 3P, which I tow with) will eliminate the sway completely.
If he has P rated tires on the TV, no hitch will eliminate the sway. He has to get LT LR D at a minimum on the TV. JMO
sway, towing, truck
