Old 07-25-2017, 02:47 PM   #1
Turn Lamp Fault Indicator
I have a Heritage Glen 272BH and have recently gotten a "Right Turn Lamp Fault" message in my truck. Brake lights and left turn signal are both fine. This happened today while hooking up. While trying to figure out a cause, it started working again. While driving on the interstate, I got the fault message again, then it went away again while driving. The bulb looks good. Any ideas? Could it be the seven way connector?
spurticus is offline   Reply With Quote
Old 07-25-2017, 04:15 PM   #2
Head Rambler
Most tow vehicles don't have lamp out indications for the towed vehicle.
Also, the towed vehicle usually isn't tied directly into the tow vehicle lighting.
Which TV do you have?
My guess is that you either have a bad lamp or a bad connection at the socket.
Gotta go campin!
Old 07-25-2017, 04:37 PM   #3
Originally Posted by bama rambler View Post
most tow vehicles don't have lamp out indications for the towed vehicle.
Which tv do you have?
2016 f250
Old 07-29-2017, 08:27 PM   #4
Had the TT at the dealer for something else and had them take a look. They advised the turn Lamp on the TT itself was fine. I was advised to clean the connections on the 7 pin trailer connector with wd40 and a small wire brush. They said it didn't take much to sometimes throw off the connections.
cat
