Old 09-26-2014, 12:53 PM   #1
TV connection
I just got a 2011 wildwood 22' trailer. I want to hookup my satalite reciver to it. I have a outside cable hookup, inside is a face plate with the 12v plug, and a coax. cable onecction. Also there is a face plate with 2 RCA jacks, 1 red, 1 yellow, . I hooked the dish cable to the outside but dont get anything inside on the coax. fitting. Any ideas??
jimmyc627 is offline   Reply With Quote
Old 09-26-2014, 01:46 PM   #2
BooBoo23's Avatar
The satellite signal will not pass (conduct) through the wall amplifier/splitter. You need a separate coax connection for a satellite receiver. If you have no outside satellite connection port you will need to install one yourself and run RG6 coax to a place inside your RV where you can put a separate wall outlet to hookup the receiver, or just run it through a window or door opening.
Newer RVs have a satellite port on the outside but apparently yours is to old to have that installed already.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
Old 09-26-2014, 01:51 PM   #3
RCA plugs
can anyone tell me what the RCA jacks for?
