Old 07-01-2015, 03:36 PM   #1
TV Mount 262bhxl
Anyone know how to mount a tv in the X-Lite 262bhxl? Can't tell what the support structure is like in the TV recess inside. Owner's manual doesn't specify.
2014 Wildwood X-lite 262BHXL
2015 GMC Sierra 2500HD Diesel
1999 Dodge Ram 1500
JCJeep is offline   Reply With Quote
Old 07-02-2015, 04:18 PM   #2
Thekipkers's Avatar
The entire area is a backer, we choose a mor ryde mount for ours, allowed the most stability and we could swing the TV out to see it easier at the couch.
SK2 Camping Crew
2010 Ford F-350 Lariat
2015 Heritage Glen 356QB
Thekipkers is offline   Reply With Quote
Old 07-13-2015, 08:24 PM   #3
can you post up some pictures? curious how that works/looks.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
Old 07-15-2015, 11:10 AM   #4
Thekipkers's Avatar
Sorry I do not have any pictures as we have traded that unit in. Here is a link to the mount we purchase. We installed a 32" LED TV on it and it was very secure. Only issue we had was the mount sticks out pretty far to allow for the articulation ability and the TV came close to touching the slide when it was pulled in. We just placed a small blanket between the slide and TV to prevent possible damage if we hit some good bumps.
MOR/ryde TV1-025H TV Mount Double Arm Locking
A caution during install, when marking your holes, make sure you are centered. I took the swing arm off the mounting brack and marked all the holes, after drilling and install the TV was offset towards the slide, I had to take it all down and center it with the swing arm and tv bracket.
Old 07-31-2015, 11:57 AM   #5
Thanks Thekipkers, that helped. I did this before heading off to Grand Tetons and Yellowstone.
1999 Dodge Ram 1500
mount, tv mount
