Old 05-21-2012, 01:20 PM   #11
Thanks for the info, I measured and I have about 1 inch of material to work that separates either side of the cabinet. I think my only option at this point to put some sort of a strong back on the bedroom side. I plan on eventually mounting another smaller flat screen in there so I am going to put up the same mount that I have for the other side and sandwich the whole thing together. I will post pics when its all done.
gchaloner is offline   Reply With Quote
Old 05-21-2012, 01:38 PM   #12
I would bet that you have something similar to mine, a layer of "paperboard" or something on either side of a single sheet of half or three quarter plywood.
Jhawkfan44 is offline   Reply With Quote
Old 05-22-2012, 10:49 AM   #13
I got it installed, I used a small piece of 3/4 plywood and got some 5/16 bolts with lock nuts. I used the same mount for both sides of the wall and sandwiched the 3/4 ply between the two mounts. Seems very sturdy and after drilling through the small wall in the entertainment cabinet, there was a structural member that I could have used short lag screws to mount the tv with. I think the way I did will work good for my application. Thanks for all the advice.
Old 06-04-2012, 10:55 PM   #14
I used screws, nuts and fender washers. I drilled straight thru and thru bolted the living area tv mount.
The living area has a sharp lc-26v490u.
The bedroom has a dynex 11h20b.
I used the following mount for the living area.
Locking Cantilever Mount - Mcnaughton Inc 94139 - TV Accessories - Camping World
I used the following mount for the bedroom. I attached the bracket to the bolts from living room mount. I had to modify the bracket some.
Level Mount DC30SW Fixed Wall Mount - Walmart.com
Morganw351 is offline   Reply With Quote
tv mount
