Old 06-18-2016, 12:20 PM   #21
PAW International
TV bracket
I would only use a polymer TV bracket if you are going to attach one to the outside of your RV. I've replaced a panel already on my old RV and it wasn't cheep! PAW International is the only manufacturer I found that carries a variety of polymer TV brackets. Both white and black. I don't care if they are powder coated, if they are steel, they will rust eventually. I found out the hard way. The polymer brackets cost about half of what a steel brackets will run you to boot. The reduced weight is also a plus. I've found them on both Ebay and Amazon. Look for polymer TV bracket.
hitechceo is offline   Reply With Quote
mount, tv mount
