Old 03-31-2015, 11:38 AM   #1
azdesert54's Avatar
Wink TV Mount on Wall
I have a 2016 261BHXL, and want to install a TV bracket on wall behind the dinette.
Is there anyone that has installed a TV bracket? I have a 22" flat panel TV that I want to hang on the wall. It is a fixed bracket, not a swivel.
Also, do you know if the studs are metal or wood inside the wall?
azdesert54 is offline   Reply With Quote
Old 03-31-2015, 08:55 PM   #2
Going to mount mine tomorrow, I will post when im done
acris60 is offline   Reply With Quote
Old 03-31-2015, 10:10 PM   #3
azdesert54's Avatar
Watching for results
I will be watching for your results. Thanks for responding.
Old 04-01-2015, 07:57 PM   #4
Hi azdesert.... I mounted my 32" today. What I did, was cut a piece of 3/4" plywood, 5" x 6". I screwed this to the wall in the dinette. If you look where the bunk bed frame is for the top bunk, it runs through the wall of the dinenette. I guessed that it is 2" wide.... My bracket was 5" high so I screwed the plywood so it was centered along the bunk frame, 4, 3" screws. My TV is 32" and the "V" mount I bought holds it no problem. I'm pretty sure that you could mount a 36" TV this way with no problems. Of course I take it down for travel, but this seems to be the easiest and most secure way I found. I will paint it brown to match. If you want a picture of the bracket install let me know.
Old 04-02-2015, 11:37 AM   #5
azdesert54's Avatar
Thanks for you input. Please send pics.
Old 04-02-2015, 12:00 PM   #6
D_B Travelers's Avatar
Same question as I have
I am mounting a flat screen TV bracket in the bedroom of a Windjammer and have the same question basically. The area had a sticker on it telling me this is where to mount the TV, but I don't see anything that tells me what type fasteners to use. The wall has something very solid behind the paneling, plywood I suspect, so I am thinking a course thread wood screw? Or should I use a molly type insert or plastic tap in insert with a screw? I would really rather not open the door to find the TV on the floor Anyone have a suggestion? Oh, on this forum I know there are suggestions, but one's that have worked successfully!
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 04-02-2015, 12:50 PM   #7
D B Travelers, I mounted a 24" flat panel in the front bedroom of our Crusader 296BHS using course wood screws to mount the bracket. I know its not the best thing but we leave the tv mounted more than we take it down and have not had any trouble. There was a sticker on the wall saying mount tv here.
Steven379 is offline   Reply With Quote
Old 04-02-2015, 01:15 PM   #8
Take the TV down while traveling
mike.t is offline   Reply With Quote
Old 04-02-2015, 02:03 PM   #9
BuckeyeGal
TV mounting
Check forum for info on tv mounting I found out my Sabre had an aluminum plate in wall above bedroom window for TV mount. Maybe yours has same
Terry
buckeyegal is offline   Reply With Quote
Old 04-02-2015, 02:07 PM   #10
Traveling with the TV
I have a call into the Service Manager at a local RV dealership asking which fastener to use. I'll post it as soon as I get an answer. Mike - The TV is a 23" flat screen and I purposefully bought a mount that locks back against the wall so I don't have to remove it each time. The swivel goes back and locks the TV in a centered position so I think it will be okay. the TV will stay in the TT from now on, and I really don't want to have to take it off and put it back as we travel this summer. The 32" in the living room stays mounted and it is just on a french cleat (of sorts). I may just try the course screws and keep an eye on it. Thanks everyone for the feedback.
Old 04-02-2015, 02:19 PM   #11
NJOY
Old 04-02-2015, 02:21 PM   #12
azdesert54's Avatar
In my TT, there are no stickers on wall stating to mount here. I am waiting for acris60 to send a picture of what he/she did with the plywood for making the mount more stable.
Old 04-02-2015, 02:36 PM   #13
AZ. Push on the wall. You can feel the supports inside.
Old 04-02-2015, 02:40 PM   #14
azdesert54's Avatar
Thanks mike.t. I did push on the wall, and it seemed to be a vertical stud square in the middle. But, am not sure. I used a stud finder, and didn't show that there was something there. I just don't want to drill holes in wrong places. Very paranoid. I am going to mount the TV mount tomorrow, and go by the best, (in my opinion) way to do it in this forum.
Old 04-02-2015, 03:06 PM   #15
I just spoke with the service department people and they said the Rockwood had a 3/4" plywood backer in the wall and to use 1 1/2" wood screws for the TV mount. They said that was what they used when they installed a TV mount. Do use decent wood screws, not the black drywall screws that will shear off easily.
Old 04-02-2015, 03:10 PM   #16
khocke's Avatar
I've had my eyes on this item.
Universal TV / RV Computer Monitor Bracket --2 piece set--(BLACK)
khocke is offline   Reply With Quote
Old 04-02-2015, 03:41 PM   #17
I saw that one when i was shopping around, and it looks very sturdy. But mine is going to stay in one spot anyway, so the swing arm type was better for me. Camping World Master Mount Locking Master Mount Locking Cantilever Mount, Small - McNaughton 94139 - TV Accessories - Camping World, I think they are on sale right now for about $50.
Old 05-01-2015, 08:29 PM   #18
schwabml's Avatar
I used this TV mount in my 2016 261BHXL and it has worked well. I mounted right where the sticker was on the wall with the screws that were provided with this mounting kit.
http://www.amazon.com/gp/aw/d/B003O1...RPL&ref=plSrch
schwabml is offline   Reply With Quote
Old 05-03-2015, 05:43 PM   #19
azdesert54's Avatar
schwabml:
Thanks for your help. It is nice to find someone with the same model TT as I have. My problem was that there was no sticker where the TV mount should be placed. I went ahead and mounted the same bracket as you had shown on Amazon a couple of weeks ago. Took a trip with the trailer to Sedona, AZ for 5 days, and the TV mount worked great.
Where do you live? I am in Mesa, AZ.
Old 05-03-2015, 09:56 PM   #20
schwabml's Avatar
Azdesert54:
We are in Montgomery, AL. I just installed another TV by the cable jack in the front bed area. I found out that that wall doesn't have the same support as the one by the table. I had to mount close to the edge so I could lock it into the support board on the wall.
mount, tv mount
