Old 09-19-2017, 05:18 PM   #1
Under Sink Filter
Just wanted to see what people are using for under sink filters.
We are full time and stationary but the water in our area is terrible. I'm tired of buying bottled water and would like to find something i can install under the sink in the kitchen to get good tasting water.
The trailer is a 356QB
Thanks!
justin81 is offline   Reply With Quote
Old 09-19-2017, 06:50 PM   #2
I put a inline filter for the entire fresh water system plugs right into the fresh water hose and then goes into the trailer
StressedVines Wine is offline   Reply With Quote
Old 09-19-2017, 08:44 PM   #3
Is it a multi canister system, or just the single inline that you replace every so often.
the more i research the more i think a multi canister filter may be the way to go and just filter everything coming into the trailer.
Old 09-19-2017, 09:05 PM   #4
Mine is a single canister
Old 09-20-2017, 12:05 AM   #5
Thanks!
I used a blue, inline filter that goes on to the hose that provides the city water.
Sent from my XT1585 using Forest River Forums mobile app
otrtrucker is offline   Reply With Quote
Old 09-20-2017, 11:19 AM   #6
I would recommend getting a house-style filter (clear housing, replaceable filter inside) for the outside of your camper. This catches the sediment and protects all your fixtures.
Then, for drinking water, get a multiple filter setup (ideally with reverse osmosis) to put under your sink and drill a hole for the extra water tap for drinking water.
mkosu04 is offline   Reply With Quote
Old 09-24-2017, 08:22 AM   #7
Camper
I use a dual canister system and it stays outside. It uses standard 10" filters that can be found easily.
I got it from rvwaterfilterstore years ago.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
sink
