Old 07-06-2016, 07:00 AM   #1
Vent design/location
The fresh water tank does not appear to be venting as I fill it. Air pressure builds up and blows back at the filler neck. I don't see a vent on the roof to check for dirt dobbers. Any suggestions?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 07-06-2016, 08:43 AM   #2
The fresh water tank vent is usually a small screened opening in the fill neck fitting, or a small tube coming from the top of the tank hanging under the RV with a screen on it.
It won't be on the roof, and it could be missing the screen. If it's not in fill fitting, start by looking under the unit near where the water tank is.
Gotta go campin!
Old 07-06-2016, 09:24 AM   #3
Found it -- thanks!
It is a small screened opening beside the filler neck, built into the same fitting. Now to figure out why it is not venting as it does not appear to be blocked. Hmmmm
Andersen hitch
Old 07-06-2016, 10:48 AM   #4
There have been reports of the tubing being kinked between the tank and vent screen.
Gotta go campin!
Old 07-06-2016, 11:02 AM   #5
Yes, that is the problem. Two kinks as it exits the tank (black hose in pic). Too close to trailer floor. It needs a 90 degree elbow if I can find one.
Old 07-06-2016, 11:10 AM   #6
As much of this stuff as I see I'm still appalled at the shoddiness of this!
Gotta go campin!
Old 07-06-2016, 02:25 PM   #7
They had to have seen that when it was installed. I suppose they thought it would heal itself (or, more likely, that I would repair it for them as I'm about to do.)
Andersen hitch
Old 07-06-2016, 02:30 PM   #8
Restcure's Avatar
I'm guessing that's under your trailer and accessed from the bottom?
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 07-06-2016, 04:40 PM   #9
Yes, underneath. I took the pic lying on my back, looking up. I think I can access it without dropping the tank. I hope so!
Andersen hitch
Old 07-07-2016, 09:03 AM   #10
Issue repaired
I replaced the fitting with a 90 degree elbow and slightly rerouted the vent hose. Tank is now filling properly with a strong flow of air coming out the vent.
If anyone is interested the fitting is a nylon hose barb from Lowes, size 1/2 inch hose barb X 1/2 inch MIP.
After filling the tank I can see why some have had issues with it dropping out. Altnough I will rarely be traveling with a full tank I think I will research the threads on adding support straps.
Andersen hitch
Old 07-07-2016, 09:19 AM   #11
Thank you very much for coming back and letting us know the fix. We appreciate you posting the pictures of the problem also. It helps people in the future greatly to be able to see what their problem may be.
Gotta go campin!
Old 07-07-2016, 10:00 AM   #12
Glad to do it. Due to the design I suspect there are others with this issue. Thanks for your help!
Andersen hitch
cat, location, vent
