Old 12-03-2018, 07:42 PM   #1
Lpc
Water Faucet Aerator
Hi
Iím trying to install a kitchen water faucet filter. The threads are internal and I canít figure out how to remove the aerator in order to install the facet filter.
Sounds so simple yet I canít figure it out.
Please Help
Lpc is offline   Reply With Quote
Old 12-11-2018, 07:56 PM   #2
They are pretty low quality facets. It may not be removable.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 12-11-2018, 08:35 PM   #3
TLAK's Avatar
It should unscrew like a lightbulb. If you have one of those rubber bottle top openers it helps. If you are going to toss the old aerator anyway, go ahead and use a pair of plyers on it.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 12-11-2018, 08:38 PM   #4
cavie's Avatar
righty tighty lefty loosy
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-11-2018, 08:42 PM   #5
Just as confused as you
Scrapper's Avatar
All aerators need to be removable to clean them. You may have to use a pair of channel locks with a towel or rag on the aerator.
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 12-11-2018, 10:15 PM   #6
bubbles's Avatar
If it's a MOEN you may need one of these keys (they're color coded by size).
Old 12-11-2018, 10:54 PM   #7
bikendan's Avatar
They aren't going to be putting Moen faucets in a Wildwood.
Equalizer WDH
Old 12-12-2018, 07:05 PM   #8
X2, any camper for that matter. I think my unit has a 2.00 plastic Chinese facuet.
Kimber45 is offline   Reply With Quote
Old 12-13-2018, 07:19 AM   #9
nomad297's Avatar
MOEN or not, most faucet manufacturers are starting to use these internally, o-ring-sealed aerators with a castle nut-type end. There is no standard between manufacturers, or, in many cases, with one faucet to another from the same manufacturer. If I had a different key for every aerator, I wouldnít have room in my tool bag for anything besides aerator keys. Most can be removed by starting to turn them with sharp needle nose pliers or retaining ring pliers, then finish by turning them out with a finger. You donít need to replace them as tightly as they were originally installed ó just use your finger to screw them up enough to where the o-ring seals and your finger begins to not be enough to tighten them any farther ó donít crank them back down with the pliers you used to loosen them. They will stay in-place and be easier to remove the next time.
Bruce
nomad297 is online now   Reply With Quote
Old 12-13-2018, 07:29 AM   #10
bubbles's Avatar
Gees. I guess I should have said similar to MOEN. The OP said internal threads and thought he was referring to the aerator. I've had MOEN and GLACER BAY faucets in my units and it was only an input. let it go Louis, let it go.
faucet, water
