Old 09-12-2013, 12:14 AM   #1
simplyrwc's Avatar
Water filter
Anyone know where the water filter is located on a Wildwood 32bhds?
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 09-12-2013, 06:47 AM   #2
TURBS's Avatar
Normally right next to the water pump.
Since you didn't mention a year a better answer can't be told.
Turbs
Old 09-12-2013, 01:24 PM   #3
simplyrwc's Avatar
It's a 2014. I looked there and didn't see one.
2013 Days Camped 14
Old 09-21-2013, 02:53 PM   #4
Big Bad Allis's Avatar
You might not have a water filter. There is a screen by the pump but its not a filter. I use an external filter in the water line before it enter the trailer water system.
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 09-21-2013, 05:17 PM   #5
On our 2010, 27fbs, it is in the bathroom under the wardrobe, under the power unit, and inside of the cabinet under there. We don't use though. Use an external water filter instead.
2004 F150 4.6 Griffin tuned
2010 Wildwood 24FBS
johnleann is offline   Reply With Quote
Old 09-22-2013, 09:30 AM   #6
Should I be looking for one? I haven't seen anything that is integrated other than the screen by the pump. I have been using the external set up since I didn't think my trailer had an internal water filter.
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 09-23-2013, 12:58 AM   #7
simplyrwc's Avatar
I still never found one. Only use fresh water for showers, washing and brushing teeth. Am going to assume normal tank sanitation should be enough for that.
2013 Days Camped 14
Old 09-23-2013, 06:17 AM   #8
TURBS's Avatar
Its pretty uncommon To not have a factory water filter.
A) If you live in a cold climate you'll likely find it next spring.
B) eventually it will become plugged.
Turbs
Old 09-23-2013, 08:00 AM   #9
My RV didn't come with a factory water filter.
Old 09-23-2013, 03:20 PM   #10
Terier's Avatar
My TT didn't come with a water filter either.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 09-23-2013, 03:42 PM   #11
schrederman's Avatar
My TT came with one. It was under the kitchen cabinets with the fresh-water pump. I removed it and use it outside the trailer. As someone posted above, mine froze and broke, but landed like a tumbler, and didn't spill its contents, (lucky me...) That's why I moved it, so I could make sure everything drained and pump antifreeze throughout the system. I bought a new one at Lowes for about $30-. I already had a dozen or so of the filters because our last home had a well, and these filter cartridges fit that filter system... When you change the cartridge after camping off and on for a year, you'll see why it's a good idea to use a filter.
Enjoy...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
