Old 05-17-2016, 04:47 PM   #1
Question Water Filter on 2016 Wildwood 26TBSS
We have looked high and low on this thing for the water filter.
Behind panels in kitchen and bath. Do we not have one?
Is it hidden behind something?
Our Mini Lite had one, just assumed all Rockwoods had one.
Anyone know for sure?
Karen
2012 F150 Screw XLT
4 legger Halley
TreeLady is offline   Reply With Quote
Old 05-19-2016, 07:27 PM   #2
Wa11y757's Avatar
Probably don't have it. My 2016 27rkss didn't either. However, it was super easy to install an in line, on the cold side only for coffee, in the kitchen. It goes down to 5 micron. Every thing is filtered with the camco 150 micron outside at the hose.
Wa11y757 is offline   Reply With Quote
Old 05-20-2016, 05:14 AM   #3
Thanks, Wa11y,
We decided that if it is hidden behind a panel, we don't want to mess with it. Easier to use the filter on the water hose.
We also discovered that some hot rod with a caulking gun put a dab of caulk over the breather hole on the filler opening for the fresh water tank. Really??? Not sure we can poke enough holes through the clogged screening for the hose to breathe. Trying that today. If not working, going to dealer for a new filler cap.
2012 F150 Screw XLT
4 legger Halley
Old 05-20-2016, 06:34 AM   #4
Wa11y757's Avatar
That hole is caulked fo a reason. There is a breather hose on the top off the tank that should extend out the bottom of the tt. I think they plug the the one ur talking about so nothing can "run" into it contaminating the tank. Look for 2, usually white and one with a valve, poking out under the tt.
Old 05-20-2016, 08:26 AM   #5
thank you for that info.
Did not know this. Will have DH crawl under trailer and look. He has already been under tying up loose wires and checking other items.
These camper units all have their own quirks. Still learning and trying to figure things out.
First outing with this new unit this weekend. Hoping we got everything covered.
Karen
2012 F150 Screw XLT
4 legger Halley
Old 05-20-2016, 09:50 AM   #6
Originally Posted by TreeLady View Post
Thanks, Wa11y,
Just an FYI, if you do have one, you'll probably want to find it before you have to winterize. They are notorious for cracking if you don't get all the water out and they freeze.
Iwritecode is offline   Reply With Quote
Old 05-20-2016, 11:37 AM   #7
Thank you, we did think about that but so far Wa11y is right. No filter.
Then the next issue was not being able to fill the fresh water tank. DH pulled fitting off, then looked under the fridge and the fill hose was going uphill! Got that adjusted and got the tank filled.
NOW, we can't get it to drain!! Valve turned open but it is just dripping! Now what?
Going to search forum for some help if you and Wa11y can't help.
2012 F150 Screw XLT
4 legger Halley
Old 05-20-2016, 12:03 PM   #8
Wa11y757's Avatar
If it can't drain, maybe it's vacuum locking due to no vent...maybe ur "vent " is caulked over. Dang.....so many options on these things...
Old 05-20-2016, 12:07 PM   #9
I think I would rather have a used camper again. This unit is brand new. What a pita.
Will see if DH can find what is going on with your suggestions.
Thanks again.
2012 F150 Screw XLT
4 legger Halley
Old 05-20-2016, 12:14 PM   #10
Look by your water pump. Did you find that?
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
26tbss, water, water filter, wildwood
