Old 07-24-2012, 02:09 PM   #11
Our 2012 Wildwood XLite 24QB has the 6 gallon water heater with the DSI and electric heater. There is a switch down in the lower left corner somewhat hidden by the gas burner pipe works. Must pull pin and turn it on. We have only used it once. Almost always use the gas mode.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 07-24-2012, 02:16 PM   #12
TURBS's Avatar
Originally Posted by Dave_Monica
If I recall correctly, the elect/gas WH was a $100 - 150 option on our first Rockwood TT we purchased, but it doesn't appear as an option with the Wildwood Xtralite.
Dave
I see some nee units now are coming with 12 gal dsi.
Old 07-24-2012, 02:25 PM   #13
Dave_Monica's Avatar
Ron, 12 gal WH seems like a little overkill unless you're camping with 5 or 6 souls or have full hook-ups and enjoying long showers. We've never run out of hot water with the 2 of us and 6 gal capacity always running on 120V alone.
Dave
Old 07-24-2012, 02:31 PM   #14
TURBS's Avatar
Dave
I think our 10 gal is sufficient as well.
My dw and I are the on only ones to use it.
Kids go to shower house as they enjoy long unmeaningful hot showers.
That's there choice
Old 07-28-2012, 07:54 AM   #15
Attached are pictures showing the rocker switch for HWH with electric heating as well as DSI propane.
Ottawa, KS
2013 Forest River Wildwood 26TBSS
2010 Nissan Armada SE 4x4
Http://campingkansans.blogspot.com
Jhawkfan44 is offline   Reply With Quote
Old 07-28-2012, 07:58 AM   #16
Even using gas AND the electric heating, it seems that we run out quickly. When we give our 1 year old a bath, the water turns luke warm in no-time...
Will a larger tank fit in our 26TBSS? Or should I look at instant heat units?
Ottawa, KS
Old 07-28-2012, 09:57 AM   #17
TURBS's Avatar
Is one of your weatherization valve turned slightly ?
Outside side shower knobs turned on if so equipped?
I had a 6 gallon heater in my Tt that worked for 5
Old 07-28-2012, 10:19 AM   #18
Where is the weatherizarion valve and what does "turned" mean? Like leaking? Are those the two water lines near my sewer valves?
(I've planned to have my dealer help me
Winterize the first time)
Ottawa, KS
Old 07-28-2012, 12:42 PM   #19
TURBS's Avatar
Your winterization valves are behind your Hw heater.
Old 07-28-2012, 03:36 PM   #20
Bilcin's Avatar
On my 2011 26tbss the acess panel to the valves to winterize it is inside below the sink, it is a wooden panel with 4 screws. Once panel is off the valves which are are red and blue. shut off the water intake valve to the heater to winterize the heater then on the outside remove the large bolt in the center os the water heater to drain the water.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
