09-23-2008, 10:21 PM
Water heater plug
I am attempting to remove the drain plug to drain my water heater for the winter and need a little help. I have a good supply of tools and sockets but not the right one. I measured the plug with my tape measure and got exactly and 1 1/8 so I bought one and an 1 1/4 socket, and neither fit, too big. Since I live a ways from town and the store I didn't know if anyone knew the exact size before I made the return trip to town, metric or standard? The camper is a 2009 Wildwood 26TBSS with the electirc/gas water heater.
Brock525
2005 F150 SCrew Pullin'
with 2 little ones and the Boss
09-24-2008, 05:02 AM
My hot water plug is an 1 1/4" that's on a Rockwood. My socket will not go on smooth, I have to fiddle with it.
09-24-2008, 06:52 AM
The drainplug/anode rod in our Surburban water heater is 1-1/16". I've used a basin wrench to remove them too.
Gotta go campin!
09-24-2008, 07:07 AM
Mine is also 1-1/16 and it is also a plug/anode.
My previous 2 trailers had a plastic drain plug and no anode.
They were a smaller size, maybe 7/8.
If yours is kinda rusty steel with a little bump in the center,
it's likely an anode/plug like we have now.
Peace!
Dan & Rita D
09-24-2008, 07:20 AM
same same here as well
have you tried a cresent wrench?? kind of awkward but it'll work.............
09-24-2008, 09:11 AM
My Flagstaff is 1 1/16" I used a 12 point socket with an extension 1/2" drive. It all so is a Suburban.
09-24-2008, 11:12 AM
i use a 6 point
but if the rod has been in a while
spray some PB blaster or wd-40 on the exposed threads
anode rods are cheap, if its pitted up i would change it out
also make sure the electric is turned off and the pressure has been released by opening the OP valve.
i also run water through it till its cool to the touch to prevent a burn if the heater has been on
Living in the Piney Woods of Texas.
09-24-2008, 07:03 PM
So I am the odd ball with 1 1/8"
09-24-2008, 07:10 PM
i dont think its a standard
1 1/8 is only 16 th larger, it will work to on a 12 point socket, i woulndt worry about getting branded "odd ball"
09-26-2008, 08:27 PM
Thank you all that replied, it was a 1 1/16". I also tried the cresent but there was no way it was going to happen. Thanks again.
Brock525
10-06-2008, 06:30 PM
mine is 1 1/16, but i only had a 1 1/8, i was able to remove but it is difficult to remove the anode from the socket, i finally got it though.
i had plumbing almost in front of the anode so using other wrenches with an extension on a socket didnt work.
glad you found the socket that best fits
2008 Wildwood LE 29BHBS
