Old 02-08-2010, 09:54 PM   #1
Water in the trailer
I own a wildwood 26fks that recently was caught in the rain going thru Death Valley National Park. During the storm, I had water collecting at the following points:
Right front corner - I have modified the trailer and removed the bench seat
to have regular chairs at the table, therefore, allowing us to see the right front corner
Front Door Left side
Has any else had this issue with their wildwood and where is the likely spot to look?
CAN-DO
CAN-DO is offline   Reply With Quote
Old 02-08-2010, 11:49 PM   #2
It could be coming from a window or maybe a seam thats needs recaulking in the front .Really kind of hard to say without looking at it and as far as the door it could be a bad seal. When driving in a storm water it forced into place where it wont normally go so check and see if it leaks when sittng in drive way or a camp sites and an 06 is probably due for a recaulking any way. I know this is not much help but may give you some where to start looking
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 02-09-2010, 10:17 AM   #3
MtnGuy's Avatar
Also for that leak in the right front corner, check the caulking around your marker light. I had a leak in that area, and recaulked the seams without remedying the situation. I found a tiny crack in the marker lite caulk, and correcting that solved my problem.
wildwood
