Old 05-12-2019, 11:41 AM   #1
Water issue and fresh tank issues.
Wildwood Heritage Glen
Last night, we had water pooling under the right side of the TT near the stairs and close to the water pump from what I can hear.
We then had our grey water tank read 1/3 full and then water came rushing out from the underbelly near the rear grey/black drain pipe. See attachments.
Anyone familiar with these issues?!
ID:	204367   Click image for larger version
Foofoo7788 is offline   Reply With Quote
Old 05-12-2019, 12:26 PM   #2
fonzie's Avatar
See this thread for possible cause and fix.....
Fresh Water Filling Up by itself?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-12-2019, 12:32 PM   #3
That solves one issue, still a mystery on the water pooling and leaking from the underbelly
Old 05-12-2019, 12:39 PM   #4
fonzie's Avatar
Could be the overflow form the fresh water tank if water is back feeding through the water pump.
Fonzie
Old 05-12-2019, 12:59 PM   #5
primo20's Avatar
i had an almost identical situation this weekend - first time out since last winter.
my water stopped leaking out of the underbelly when i turned off the city supply - but the pump would prime to draw water into the trailer when i went to tank supply. the pump wont stop running, it just bubbles water and constantly runs - but doesn't pick up from the fresh tank or dump in the grey tank.
I'm thinking a cracked waterline somewhere in the behind my p1 nautilus water system - wont allow the pump to build pressure, but leaks into the underbelly. mine goes in to get fixed int eh morning - warranty coverage. ill let you know they find.
can i piost a video here? if so i have a couple of my issue.
2018 DURANGO 2500 343MBQ | 2017 Ram 2500 Cummins
primo20 is offline   Reply With Quote
Old 05-12-2019, 04:50 PM   #6
dadaddy's Avatar
I have a 2010 Sierra. Had similar issue with mine. Turns out the selector valves(city, gravity)etc. have plastic handles on brass stems. The valve handles wear so you cannot tell whether the valves are completely open or closed. They can appear to be fully open or closed but still bypass water. Only after removing one of the handles could I tell the valve was not completely closing. Hope this helps.
[FONT=Arial][SIZE=3][COLOR=black]Wayne Taggart [I](Dadaddy)[
dadaddy is offline   Reply With Quote
water, tank
