Old 08-06-2017, 10:30 AM   #1
water pump on or off when hooked to city water
It seems that no matter where we camp the water pressure is not that great. does the water still go through the water pump when connected to city water? if so then should I have the pump on (like when I'm in the shower).
Sawtooth is offline   Reply With Quote
Old 08-06-2017, 11:16 AM   #2
When on city water it doesn't flow thru the pump. Check the screen where your hose hooks up to the city water inlet on your camper, it might be dirty/clogged. Then check the airators/ screens at each faucet too.
Old 08-06-2017, 12:20 PM   #3
bikendan's Avatar
NO
Water pump is separate from city water and will not help with pressure.
Equalizer WDH
Old 08-06-2017, 02:10 PM   #4
Thanks for the good advice. I'll check.
Old 08-06-2017, 02:16 PM   #5
If the park water pressure is actually low, we disconnect from the park supply and fill up our fresh tank. Then we turn on the pump and just use the fresh tank water supply.
Old 08-06-2017, 06:16 PM   #6
agree with nmwildcat. there is probably a valve that routes the incoming city water either directly to plumbing system (in which case it will reflect the city water pressure) or to the fresh water tank. if you route the water to the fresh water tank you will need to turn on the pump to get it out of the tank and into the plumbing system (in which case it will reflect the pressure from the pump).
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-06-2017, 06:19 PM   #7
markb5900's Avatar
Do you have an incoming pressure regulator on your hose?
If so, is it adjustable?
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-06-2017, 06:24 PM   #8
I have a prreg. Not adjustable.
Old 08-06-2017, 06:27 PM   #9
Somewhere in the literature I recall the statement that the water pump can be damaged if used when connected to city water. Don't have a plumbing schematic but won't test the statement.
dmax36 is offline   Reply With Quote
Old 08-06-2017, 06:28 PM   #10
markb5900's Avatar
Since you say it has happened at multiple campgrounds, I would go buy another regulator first.
It may be bad or clogged up.
They are a cheap fix before you dig to far into your rig.
Mark B
2017 GMC 3/4 Ton TV
city water, pump, water, water pump
