Old 09-20-2012, 01:23 PM   #1
Water system WW261BHXL - Low Point Drain
just finished sanitizing and during the process I noticed 2 "drain" lines under the almost rear end, left side - have a placard on the tt vertical side reading "Low Point Drain"
can someone tell me their function (it's 2 lines, side by side, pointing down, each with a screw-on plastic cap)
Whisky is offline   Reply With Quote
Old 09-20-2012, 01:47 PM   #2
AquaMan's Avatar
These are the low point drains that drain the water from your lines for winterization. Some units have 2 sets of these depending on length and number of baths/sinks.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 09-20-2012, 02:32 PM   #3
TURBS's Avatar
DurIng wInterIzatIon You must drain those by pulling caps and opening all facets inside and allowing all water to drain.
Don't forget outside shower if u hav e one.
Remove filter.
Drain Hw tank and bypass it.
Old 09-20-2012, 02:33 PM   #4
no design engineer here but wouldn't it have been easier to simply have the system drain be the "low point" drain ?
thanks for the reply.....Bill
Old 09-20-2012, 02:34 PM   #5
TURBS's Avatar
Not sure how you could do that ?
Old 09-20-2012, 09:37 PM   #6
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
What is the system drain to which you refer?
dimurrrw is offline   Reply With Quote
Old 09-20-2012, 09:40 PM   #7
TURBS's Avatar
I believe he means when you dump the fresh water that should be your low point drain as well .
Not sure why you would want that but I guess thats what I took from it .
Old 09-21-2012, 05:42 AM   #8
what I meant was.....I believe it would be a better setup if there was ONE drain to rid the entire fresh water system, rather than more than one.....Bill
Old 09-21-2012, 06:32 AM   #9
TURBS's Avatar
I see .
Old 08-08-2013, 08:52 PM   #10
Low point lines
I have a 04 jayco 32'. I have a low point drain (two lines coming down)just outside the bath and two at the rear.
The ones outside the bath are dripping. What is going on? My lines have no caps.
Where do these lines come from? I guess I can trace them.
Thanks!!
seicken is offline   Reply With Quote
