I doubt they will sell just the gasket,use a small dia O-ring or acquire some gasket material and cut you own! All the cargo door locks I have bought Do NOT come with gaskets,but it is Best to seal that area! Youroo!!
Worst case scenario, remove the lock and place a light bead of your favorite flavor of sealant around the hole. Reinstall the lock and wipe away any excess sealant. Voila.
˄ THIS will be the fastest, easiest and least expensive way of dealing with said problem.
They are called Camlock gaskets.
Many of the replies you have received will be a great substitute but you asked where you could buy them.
You can buy them **HERE**.
Second item down # K04G
F&AM Lodge 358 Somerset, PA - JAFFA Shrine - Altoona, PA Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
