Old 02-03-2013, 03:20 PM   #1
Another rat in the race
jar3316's Avatar
What is this
This is my father in laws wildwood 5er its about 10-12 years old and has alum on the out side and siding on the inside. There is no visible marks or damage on the other side of the 5er but these appeared about a year ago can any body help him figure out what has caused it and if its a real problem or not.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 02-03-2013, 03:23 PM   #2
Av8orLou's Avatar
Looks like delamination caused by water getting in the wall somehow.
2015 GMC Denali HD Z71 4X4 - D/A
2004.5 Chevy D/A
2013 Cedar Creek 34rlsa
2003 Four Winns Funship 214 Deckboat - Hawaiian Breeze
Av8orLou is offline   Reply With Quote
Old 02-03-2013, 03:40 PM   #3
Look like staples under the wall papper working there way out..
murry is offline   Reply With Quote
Old 02-03-2013, 04:10 PM   #4
Rrickim63's Avatar
Gently press around the bumps. If its spongy,it's definitely water damage in the early stages.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-03-2013, 05:12 PM   #5
jar3316's Avatar
Its been a while since I've been in there but if memory serves its pokey in the middle and soft around the edge like a pencil pushing out.
Old 02-03-2013, 06:59 PM   #6
Commercial Member
huntr70's Avatar
Water damage....definitely.
The bumps are probably hard, they are black mold that grows under the vinyl wallpaper when wet.
Look for a leaking screw under the trim where the rubber roof meets the siding. Usually those screws can work loose over time, and the water will travel under the trim until it finds that screw. You should be able to take out the vinyl trim strip and find screws underneath it.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 02-09-2013, 07:17 PM   #7
RE:Water damage.
Definitely water damage.
Fix the leak source and clean up the affected area with bleech or other
approved cleaner.
You may need to cut out the bad paneling and replace it.
jaycee611 is offline   Reply With Quote
