Old 09-07-2019, 02:48 PM   #1
What Tank Is This?
2018 23BHXL. Any idea what tank this is? Fresh water?
Under the kitchen sink and in front of the front tire on the passenger side.
Thanks Mike
Mike Gray
Forest River Wildwood
2018 230BHXL
2015 Sierra SLE 5.3 V8 4x4
Mike223 is offline   Reply With Quote
Old 09-07-2019, 03:08 PM   #2
Blackrock's Avatar
White Plastic, Yup that's your fresh water tank.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 09-07-2019, 03:22 PM   #3
Retired Navy
The other give-a-way is the drain valve. The black and grey tanks use a guillotine valve.
2012 Lexington C Class
Toad: 2009 Honda Fit
Bob_K is offline   Reply With Quote
Old 09-07-2019, 03:38 PM   #4
Thanks. Thought it was but no manuals with the TT I just got today.
Mike
Mike Gray
2018 230BHXL
Old 09-09-2019, 09:02 AM   #5
One last question about this. It all looks like sturdy plastic including the plug. Does the plug just screw out? I don't want to break or damage it if it comes out some other way. When low drain plugs open, all fresh water in the holding tank will drain out???? No manual and just wanting to do the right thing. Thanks,
Mike
Mike Gray
2018 230BHXL
Old 09-09-2019, 09:13 AM   #6
I do not have your unit, but my experience is that the plug will just unscrew to drain the fresh water tank. When draining my fresh water tank, the water in the lines did not drain unless a faucet valve was open. The other tanks did not drain; they had to be released thru their sewer lines. I think that's pretty standard, but I'm not that familiar with all the different units. Have only had 5 travel trailers.
Greg 'n Deb
2020 R-POD 195 HRE
Tacoma and Tundra TV's
Dirt Sifter is offline   Reply With Quote
Old 09-09-2019, 09:18 AM   #7
rebeltown's Avatar
fresh water tank.
Curious, what is or isn't holding that tank up?
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 09-09-2019, 09:23 AM   #8
You may want to replace the plug with one of these:
2011 Traverse LT, 3.6L, FWD
Old 09-09-2019, 09:46 AM   #9
Or 1/2" quarter turn PVC valve. Stronger and more reliable.
TheWolfPaq82 is offline   Reply With Quote
Old 09-09-2019, 12:54 PM   #10
Not sure but it is secure. Nothing on the bottom or sides. Has to be from the top. Seems to be in there pretty good though.
Mike
Mike Gray
2018 230BHXL
tank
