06-01-2018, 04:45 PM
Wheel bearing Grease
Can I get some opinions on the brand/type of bearing grease that is best used in a Heritage Glen TT with Dexter Easy lube hubs? Prefer grease gun tube.
06-01-2018, 04:49 PM
I used Mobil 1, got a tube for my gun and a cannister to repack the bearings. Good stuff, exceeds the manufacturer's requirements.
06-01-2018, 07:57 PM
If it's never been torn down and still factory dexter grease then you will need a lithium complex grease as this is what dexter uses. All info can be found on their website.
06-01-2018, 08:26 PM
Lucas Red ‘n Tacky #2 is a good lithium complex grease. Available at Walmart for five bucks a tube.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
06-01-2018, 08:41 PM
X2 on the Mobil 1, but there is a list of approved lubes in the Dexter manual.
2018 Rockwood 8244BS
2006 F250 6 speed
[SIGPIC]
06-01-2018, 08:52 PM
I didn’t know WD40 made grease but the specs on their extreme pressure grease look pretty good. Good reviews on Amazon. Also lithium complex base.
https://www.amazon.com/WD-40-Special.../dp/B076F7MDNZ
06-01-2018, 10:15 PM
Any kind of axle grease - lithium is probably best.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
06-01-2018, 11:48 PM
I’m no expert by any means, but I have read that you should not mix different grease types. If Dexter used a lithium complex grease in your axles at the factory, then you should use a lithium complex grease, unless you clean all old grease out before repacking with a different grease.
06-02-2018, 12:08 AM
I use Lucas Red ‘n Tacky #2
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights / 2018 = 7 nights
06-02-2018, 12:35 AM
X3. Use it on my Sidewinder hitch also. Great stuff, especially in our heat.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-02-2018, 04:40 AM
Also Lucas Red n Tacky.
06-02-2018, 02:28 PM
Red N Tacky here also.
I do recommend removing the hubs and cleaning them out the first time you service them. That allows you to check the condition of the hubs, brakes, bearings and races and start off with new clean grease.
Gotta go campin!
06-04-2018, 01:13 PM
Red N Tacky here, it's good stuff.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
06-06-2018, 06:52 PM
We have not had very good braking on the last couple of trips so I decided to pull the wheels. This is what I found in the first wheel, haven't got to the other three. I know most folks recommend replacing the brake shoes after a mess like this but I'm being cheap. Talked to a couple of local mechanics about cleaning them and followed their recommendations so I'll see.
You could see where the shoes had barely rubbed the drums so I believe these brakes haven't been doing their job since almost new. Always thought the trailer brakes weren't very effective, now I know.
Two things have slowed me in doing the rest. Old age, the price of a grease seal at our local NAPA store, nearly $13, so I ordered the other 3 double lip seals from E-Trailer, $18 delivered. Should be here by next week. The local one is only a single lip seal, he wanted $28 for a double lip seal.
Hope you can see the grease on the shoes and all over the mechanism. It was a bear to clean up, brakeclean, gunk and my pressure washer got the shoes and backing plate and associated parts clean. The drum got a good cleaning in the solvent tank and them washed and air dried.
I packed the bearings by hand with a Mobil high temp grease for wheel bearings, no more grease guns on these wheels. Very tacky stuff. I had only given them 2 or 3 pumps last summer when I was replacing the tires so I don't think it was a case of over greasing.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
06-06-2018, 07:32 PM
Mobile 1
2014 Cedar Creek Silverback 31RK
2016 Silverado 3500HD Crew Cab LTZ Duramax 4X4
