Old 06-01-2018, 04:45 PM   #1
Wheel bearing Grease
Can I get some opinions on the brand/type of bearing grease that is best used in a Heritage Glen TT with Dexter Easy lube hubs? Prefer grease gun tube.
Noah is offline   Reply With Quote
Old 06-01-2018, 04:49 PM   #2
I used Mobil 1, got a tube for my gun and a cannister to repack the bearings. Good stuff, exceeds the manufacturer's requirements.
bblake57 is offline   Reply With Quote
Old 06-01-2018, 07:57 PM   #3
If it's never been torn down and still factory dexter grease then you will need a lithium complex grease as this is what dexter uses. All info can be found on their website.
whitewinghunter is offline   Reply With Quote
Old 06-01-2018, 08:26 PM   #4
Lucas Red ‘n Tacky #2 is a good lithium complex grease. Available at Walmart for five bucks a tube.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 06-01-2018, 08:41 PM   #5
X2 on the Mobil 1, but there is a list of approved lubes in the Dexter manual.
2018 Rockwood 8244BS
2006 F250 6 speed
[SIGPIC]
kamper00 is offline   Reply With Quote
Old 06-01-2018, 08:52 PM   #6
I didn’t know WD40 made grease but the specs on their extreme pressure grease look pretty good. Good reviews on Amazon. Also lithium complex base.
https://www.amazon.com/WD-40-Special.../dp/B076F7MDNZ
Old 06-01-2018, 10:15 PM   #7
Any kind of axle grease - lithium is probably best.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is online now   Reply With Quote
Old 06-01-2018, 11:48 PM   #8
I’m no expert by any means, but I have read that you should not mix different grease types. If Dexter used a lithium complex grease in your axles at the factory, then you should use a lithium complex grease, unless you clean all old grease out before repacking with a different grease.
Old 06-02-2018, 12:08 AM   #9
woodyrock1's Avatar
I use Lucas Red ‘n Tacky #2
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 06-02-2018, 12:35 AM   #10
NMWildcat's Avatar
X3. Use it on my Sidewinder hitch also. Great stuff, especially in our heat.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
wheel
