Old 10-01-2016, 02:36 PM   #21
WolfWhistle's Avatar
Originally Posted by John77lt View Post
I haven't called dealer yet. May try them Monday. I'm fairly mechanicaly inclined, figured I could figure it out myself, but no luck, lol. Thanks for all the input, I'll try and add some better pics when i get off work. It won't reach the stab jack motor, don't think it's meant to go all the way to the back where the tanks are.
It might not reach the stabs, but it might reach the connector that goes there or to the stab switch. If these devices that are not working (on same fuse) were routed to the switch (IF) and from there common grounded, it might make sense. I just wish I could crawl under there and help you.
Check the wiring diagram that comes with each rig they make LOL
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 10-03-2016, 07:54 AM   #22
Originally Posted by OldCoot View Post
I think if it is a ground wire, you would get a voltage reading of 0, not 12v. You'd get 12v if it was a hot wire.
Re-reading Witch Doctors post, it is correct IF you hook a meter from a Positive wire to a ground you will get 12+V. If you meter from the suspect wire to the frame and the suspect wire is a ground, you will get 0.
Old 10-03-2016, 10:49 AM   #23
Well my 12v issue with my slide out, awning and stab jacks is resolved!!! It was a loose negative wire in a wire nut located inside the junction box at the front of camper. That's a relief, lol. Still not sure where that darn brown wire is supposed to go, everything seems to be working fine. Think it's maybe related to the trailer wiring, but all seems to function as it's supposed to.
John77lt is offline   Reply With Quote
Old 10-05-2016, 01:28 PM   #24
Phenom's Avatar
I'm probable headed to my 28dbud in storage today or tonight to do some stuff. I'll take some pics of mine underneath and post them up so you can see what's going on.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is online now   Reply With Quote
Old 10-05-2016, 01:55 PM   #25
Phenom that would be awesome.
Old 10-06-2016, 12:31 AM   #26
2007 WildCat 32QBBS
05CrewDually's Avatar
Is that a solid core copper wire with no jacket? That's what it appears to be. If so it may be a ground that goes to a clamp on to the propane piping that runs to the rear of the coach.
Look for a clamp similar to this on the steel gas pipe.
05CrewDually is offline   Reply With Quote
Old 10-06-2016, 12:59 AM   #27
No. It's a stranded wire with jacket. Just hard to tell in picture. It's the same size wire that's used for the trailer wiring (blinkers) jist not sure why that would be grounded.
Old 10-06-2016, 11:04 AM   #28
Phenom's Avatar
I looked under mine. I have one wire ground to the frame. On the left/drivers side front of trailer. This wire go's up into the abyss to where I have no idea. As you can see I had to gorilla tape it because the hole was pretty big. Sorry I couldn't be more help.
The wire
The junction box up front
Sean
'16 28DBUD
'16 2500HD Dmax
Old 10-06-2016, 01:03 PM   #29
ThAnks so much Phenom, I'll have to look and see if there a hole leading into the abyss on mine, lol. I haven't found anything yet rhat doesn't work. Thanks for looking!
