Forest River Forums
Sunline User Photos
Old 01-22-2012, 08:36 PM   #1
Where to add 2nd (auxiliary) battery on Wildwood 26BHXL
Hi all,
Just curious to see where you would recommend I add my 2nd 12V battery to my 2011 Forest River Wildwood 26BHXL.
I got the main 12V battery from the dealer, and I would like to either add a) another identical 12V battery, or b) 2 6V batteries.
The dealer said that neither would work since there is no room up front.
As you can see, there isn't much room. Any help is appreciated. Thanks in advance.
2011 Chevy Tahoe (w/ Tow Package)
Broker777 is offline   Reply With Quote
Old 01-22-2012, 11:37 PM   #2
sherdep's Avatar
I have a diffrent camper then you but when I added my 2nd battery I had to shift the battery box and cut the plastic handles off the box to make it work.
Am pretty sure the box is bolted down with self tapping screws so you will need to remove those to be able to relocate
Looks like you have parts of the hitch in the way - maybe you can get shorter length Grade 8 bolts to replace those long ones and give you some more room or get the manual for your hitch and see if you can move the brackets forward or back to accomodate some more room
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 01-23-2012, 12:10 AM   #3
skgeorgy's Avatar
On my first trailer my dealer was able to mount a new rack thingy on top of the trailer tongue. It wasn't too expensive for them to do it. However looking at your pic again that won't work. Sorry but typing and thinking at the same time. I have also seen batteries stacked on top of each other. Your dealer might be able to fabricate something like that. I wish I had a pic to send you. I wish I had better advice.
Stephen Georgy
2011 Lacrosse 318BHS
2006 F-350
[SIGPIC]
skgeorgy is offline   Reply With Quote
Old 02-19-2012, 09:53 PM   #4
Has anyone had any luck contacting Forest River about a question like this?
If so, do you have a good contact?
Thanks!
Old 02-19-2012, 10:07 PM   #5
One thing you may consider that I did on my previous travel trailer is going to a single battery with more capacity than what you have. I had the same problem you have and really couldn't find a suitable location for another battery. I went with a Trojan SCS 225. It has reserve capacity of 225 and an AH rating of 105. In comparison an average 24 series battery is a reserve capacity of around 140. This is a big increase. I was totally happy with the Trojan. I primarily boondock and this worked good for me.
rkswyo is online now   Reply With Quote
Old 02-25-2012, 03:00 PM   #6
WFCO Converter Battery Charging with LA and AGM Batteries
Thanks for the suggestion rkswyo.
I think after looking into this that I am going to add an AGM battery inside the TT; currently looking at the Optima Blue-Tops.
One question for any of you that may know:
Our trailer has the WFCO 8955 Converter/Charger. It a 3-stage charger with bulk, absorption, and float modes; 14.4V, 13.6V, and 13.2V respectively. We boondock quite a bit and want to have extra power since on the cold nights with the DW and kids and furnace on, I wake up to a battery that is around 50%.
We currently have the Interstate DP-24 (Group 24) battery, and I want to buy an Optima group 31 AGM battery to wire in parallel with the existing battery.
I know I've read how some people say you MUST have the exact same battery Wired in parallel, and others who said it wasn't a big deal.
Now to my question: can this stock converter I have charge by the lead acid battery I have now AND the AGM battery I am planning to add, if they are wired in parallel?
Thanks in advance!
Old 02-25-2012, 03:39 PM   #7
Moderators' Assistant
bikendan's Avatar
i wouldn't put any battery inside the trailer, not even in a compartment.
Dan and Shawn and Zoe the Wonder Dog
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 02-25-2012, 03:53 PM   #8
I would agree if you are talking about the flooded lead-acid batteries, but from everything that I have read, the AGMs are safe to be put in a compartment inside.
Old 02-25-2012, 05:47 PM   #9
PapaSmurf's Avatar
What about a stack type arrangement?
2011 Silverback 29RE
1996 Ford F250 Long Bed Extra Cab 7.3 Powerstroke w /4.10
Honda EU3000is Generator
Nights camped in 2012 = 10
PapaSmurf is offline   Reply With Quote
Old 02-26-2012, 12:00 AM   #10
Unfortunately the battery is sandwiched between the propane tanks and the front of the trailer. There is no room to stack it.
» Online Users: 550
91 members and 459 guests
4runner freak, 5Galvs, Adony, amxpress, ayotte, biggie, bikeman911, BlakeB, bob213, bob34787, Bob_Loblaw, buckeyefan, Buffalohunter, camper_Lucy, Canuck_Doug, Cascade Bob, cbconway, CHD Dad, cousin01, danred, DAREK.NIEUWSMA, dashonthedash, daveinpickerington, ddurnell, dimurrrw, dknight903, dogwood36322, Doug DiLaura, dstwilsons, dunnnc, fonzie, gerrym51, go_cubbies22, grandmadonald, grhodes50, herk7769, hjgrimm1, Hob, hoffkm, Itsthetwoofus, jacksum2, jamiller45, jdefeo1, JDWeir, Jeep4Two, Joseph5410, kathomas, keep camping, kegoneill, LauraW, LChance, leanne, Mattpopp, mcbride5, merlin66043, mhartzel, MilCop4523, mtnguy, Painless, ParrotHead, pchrcane65, pmsherman, Poppy Bill, PrairieBoy, realebill, RJHuser, rkswyo, Rugged Brown, sabre5er, SabreMarv, scroses40, SDENN4281, Sg6923, Shasta1, Shawomet3, sideout1961, skipper194242, stevem4134, tedstr, texwolves, Titleguy, tonybab, Triguy, UPGRADER, vlite2011, VTX Al, waynes, Wilkrich, wolfpack21643, Yentesmj, Zama
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
