Old 06-24-2013, 08:06 AM   #131
Big Bad Allis's Avatar
Originally Posted by hokiecampers View Post
Look for one with trailer tow mirrors and factory brake controller. These are part of Max Tow Package along with upgraded cooling and rear springs. Also, I believe a Max Tow will have 3.73 ratio. Ford offers a regular trailer tow package that is just receiver hitch and electrical plug. If you go to Ford.com, build and price, you can see what is included. You can take VIN to Ford dealer and they can tell you how truck is equipped. Good luck.
I'm not up on all the gear ratios and the differences. What is the differences (ability) of the 3.31, 3.15 and 3.73?
I will be pulling a 30' trailer about 8,000 (+,-) lbs loaded. Might occasionally run through mountains but mostly flat ground here in MI.
Thanks,
Jason
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 06-24-2013, 08:31 AM   #132
I assume with that setup you have kids so you will most likely be looking for a Super Crew. If you are going to pull it on a regular basis, you would want a Max Tow and the Max Payload package with that much weight, but more specifically the payload. That puts you automatically at the 3.73.
The 3.15 and the 3.31 would not be good for that much weight and specifically the payload would more than likely be exceeded before you ability to pull the weight.
Just my 2 cents.
buckeyefan is offline   Reply With Quote
Old 06-24-2013, 08:36 AM   #133
acadianbob's Avatar
Thanks,
Jason
I higher the number, the more "leverage" the motor is provided to move the load. The higher number rear end will allow for higher engine RPM; and thus, more HP and torque available for a given road speed.
http://i421.photobucket.com/albums/pp297/acadianbob/IMG_2757.jpg
2012 F150 FX4 Ecoboost, 2016 Surveyor 274BHS
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 06-24-2013, 08:46 AM   #134
Great info. Thanks
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 06-24-2013, 08:51 AM   #135
Max Tow & Payload Pkg
I have the Supercab, 6.5' bed, 3.73 gears, 6-lug axle, 7700# GVWR with a 2000# Payload rating. The truck has the max tow package with mirrors, brake controller and transmission cooler.
The Max Tow & Payload truck has an 8200# GVWR & 2390# Payload with the Supercab, 8' bed, 7-lug axle. My friend, a light duty contractor traded in his F-350 diesel and is very pleased with the fuel costs.
I wanted the max payload (8' bed) in order to haul with a fifth wheel/gooseneck hitch, though would not fit in my garage and the DW said no way.
Of note is the 2390# payload is more than the (2200#) payload in our 2009 F-250SD, 5.4, 3.73 rear and the truck rides nice and much lower fuel costs.
{QUOTE} I will be pulling a 30' trailer about 8,000 (+,-) lbs loaded. Might occasionally run through mountains but mostly flat ground here in MI.{QUOTE}
Agree, the max tow and payload packages would make the 8K# experience more enjoyable with a 1/2 pickup. Also, you could add a bed cap and haul even more stuff (Provided you stay within the ratings).
___________________________
2012 F-150 Ecoboost, SC
2013 Flagstaff 21FBRS
2010 Trailet New Yorker, 2-Horse
HorseyHauler is offline   Reply With Quote
Old 06-24-2013, 04:28 PM   #136
dretired's Avatar
Originally Posted by rgmiller32 View Post
Looking at Fords web site the max tow package has the large mirrors, electric brake controller and heavy rear bumper. Then they offer the max pay load that has the LT tires and 7 lug wheels, etc. To get the 11, 300 towing you need booth with the EcoBoost.
Exactly !! To get a F150 thats got everything...Its almost certain that you will have to order everything to achieve 11,300 lbs Towing and a 2,600 lb payload capacity... The Max towing pkg and..the heavy duty payload pkg combined !! Dont look for one of these in a dealer search .. you might as well be looking for a uni-corn !! Especially ...in any preferred color you may want..but its the only way i would want one.. F 150 XLT Super crew ..3.5 ecoboost..6 1/2 box.. max towing pkg and heavy duty payload pkg.. 4x4 maybe or 4x2 with ..3.73 limited slip axel..7 lug rims ..E-rated tires...am i missing anything ??
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 06-24-2013, 04:38 PM   #137
ARLO
2011 F150w/ 5.oL and 3.73 gears
We tow a Flagstaff 829FKSS with our F150 The truck has 25000 miles in it andabout 9000 0f that was towing the TT. It handled the New Brunswick and Nova Scotia like a dream. Ditto for our trip around the Great Lakes.
rlocicero is offline   Reply With Quote
Old 07-01-2013, 08:25 PM   #138
I would go 4x4, besides the obvious benefits, it also gives you the 36 gallon gas tank. Not available on the 4x2
Kdz300 is offline   Reply With Quote
Old 07-01-2013, 09:54 PM   #139
wneise's Avatar
For 2014 Ford is coming out with F150 Tremor sport truck with a 4.10 rear. Wonder if we'll see that on a tow package too.
wneise is offline   Reply With Quote
Old 07-07-2013, 01:44 PM   #140
chuck9997's Avatar
Hello.. I bought a new 2013 FORD F150 STX super cab, 2wd, (5.0L, V8 with 3.31 electronic locking RR axle) a few weeks ago. I love the truck and always wanted a FORD full size.. always. I traded in a 2006 Nissan Frontier.
My Nissan actually did a pretty good job pulling my WILDWOOD 22RBXL. Camper weighs about 3500 pounds empty.. probably about 4300 loaded (no water).. but I was looking for the added comfort of pulling with the bigger FORD. The Nissan was rated to pull 6100 pounds.. the FORD: 8100, The Nissan was 265hp.. FORD: 360hp.. plus going from V6 to V8.
However.. after doing a little (after purchase) looking.. I kinda wish I had bought a truck with the 3.55 or 3.73 axle. I don't really understand what the difference is.. but i see that the towing capacity is about 1000 pounds more than the 3.31.
Anyway.. I already have the 3.31.. and it I think it will pull my present camper with no problems.. just wondering what, and how much.. you guys are towing with the 3.31 electronic lock rr axle? I might wanna move up to a bigger travel trailer someday.
I love my FORD... guess I just want to make sure I made the right choice.. over all.
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
f150
