Old 08-04-2009, 10:03 PM   #1
Wildwod Circuit Breaker
HI everyone I am new to this forum and am very desperate at the moment...LOL..My hubby purchased a used, 1998 Wildwood, 27.5 foot trailer...( notice I said hubby....)
It's in Ok condition after spending almost 10 hours cleaning it to my liking......lol
What we cannont figure out is where the circuit breaker is to run the appliances.... We hve lights, but no power in the outlests or in the appliances........Can anyone help ? thanks in advance...
LisaB is offline   Reply With Quote
Old 08-05-2009, 01:29 AM   #2
Welcome to the forum ,your fuse box is usually a brown box with two tab you have to turn to open most likely it will be close to the floor maybe somewhere like under the fridge or next to the heater, usually they are not hidden
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-05-2009, 06:39 AM   #3
KyDan's Avatar
Also, the outlets are usually "daisy chained" together with one
of them being a ground fault outlet.
That outlet controls the others.
It should have a little test/reset button on it.
Push the test button and it should click.
Push the reset button and it should stay in and turn on!
(Like Chevy2 said- you have to turn on the circuit breaker
in the power panel if it's not already on.)
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 08-05-2009, 07:26 AM   #4
Hopefully your camper is plugged in to an outlet. Lights will work off of your battery, but not anything that takes 110 volts.
2010 Rockwood 8317ss
2007 GMC Yukon XL Denali 6.2L
Prodigy Brake Controller
Wisconsin Camper is offline   Reply With Quote
Old 08-05-2009, 07:47 AM   #5
I am going out to check and see where the power panel is......lol
we have it plugged into the house right now and can use just the lights
Old 08-05-2009, 08:53 AM   #6
Head Rambler
In that panel there will be breakers and fuses. The breakers are for 120v ac stuff (receptacles, A/C, Fridge, etc) and the fuses are for the 12v dc stuff (lights, fridge control, furnace, etc).
Gotta go campin!
Old 08-05-2009, 08:44 PM   #7
you might want to check where you have it plugged into the house also. That circuit might be tripped or a GFI outlet that is tripped. Try the A/C fan and see if that will work, it only works when the camper is plugged in also.
2000 30' BHSS
2003 F350 Crew Cab
6.0
Duals/turbo back
AirAid intake
Diablo Chip
Steamintrains is offline   Reply With Quote
breaker, wildwood
