Old 09-13-2016, 05:56 AM   #1
Jonp154's Avatar
Wildwood 230bhxl 2017
Recently purchased Wildwood 230bhxl. Owners guide is very vague and pretty general. I'm unable to locate the water bypass valve to winterize, anyone know its location on this model or have other suggestions.
Jonp154 is offline   Reply With Quote
Old 09-13-2016, 12:45 PM   #2
contourcrazy's Avatar
Send a message via Yahoo to contourcrazy
My 2016 261bhxl did not have a bypass installed. I will be installing one this year when I winterize.
2016 Wildwood 261 BHXL
2012 Ford F150 XL 5.0 L
contourcrazy is offline   Reply With Quote
Old 09-13-2016, 12:55 PM   #3
Jonp154's Avatar
Wow...i assumed they all had them
Old 09-13-2016, 04:56 PM   #4
My 2014 282 bhis did not come with a bypass added it myself.
mulltrr is offline   Reply With Quote
Old 09-13-2016, 05:33 PM   #5
Jonp154's Avatar
Can you winterize the RV without a water bypass?
Old 09-13-2016, 06:19 PM   #6
I put three Galloons of RV antifreeze in fresh tank pressurized the lines with the pump and then flushed the heck outbid it come springtime. This year I am installing the bypass I was caught off guard with dropping temps and it was the lesser of the evils
2012 Ford F-150 XL 5.0L
Old 09-15-2016, 08:21 AM   #7
You can, but if you don't have a bypass then you will end up filling the WH, which takes and additional 6 gallons, plus roughly 3 or 4 more gallons so pump can pick up from tank. Can pick up a bypass kit from most any RV store fairly cheap. https://www.amazon.com/Camco-35953-S.../dp/B000BQUJL8. Also recommend install a Pump Converter Winterizing Kit https://www.amazon.com/Camco-36543-P...ANVTSQH3E2KCR0. You won't be sorry.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 09-15-2016, 01:34 PM   #8
Jonp154's Avatar
Thank you for the advice. So if I understand you correctly. Without a bypass I would need about 9 gallons of antifreeze ?
Old 09-16-2016, 12:16 PM   #9
I was able to get by with about 3.5 gallons on my 2016 261BHXL. I even have the out door kitchen sink too.
Old 09-19-2016, 08:22 AM   #10
We have the 2016 model and it has the water heater bypass located beneath the lower bunk at the rear of the of the trailer behind the water heater. Once the bunk matress is out, there are 4 screws holding the chipboard down over the rear half. Once that is removed, you can reach the valves but they are hard to reach. This was not explained to us during our walk thru and as a result, our first camping trip last Fall did not have hot water. Even after looking at it, the valve between the input and output was facing the rear of the trailer and I couldn't see it at all so did not realize it was open.
As for a Water Pump converter winterizing kit, we didn't have one. I have bought a kit but not gotten around to installing it yet. The pump is located below the Kitchen sink. Not a lot of pipe on the intake side so I haven't commited yet to the time to get down and try to install it.
Name:	WH Bypass.JPG
ID:	120643   Click image for larger version
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
2015 Days Camping : 6
2016 Days Camping : 32
2017 Days Camping : 3
Sebourn is offline   Reply With Quote
wildwood
