Old 05-07-2016, 06:59 PM   #1
Wildwood 27rkss stabilizer jacks
Hello everyone. My wife and I just bought a our first RV a 2016 Wildwood. During the walk through I could use stabilizer jacks with the button outside but now they only work with the remote. Anyone go through this problem before and know how to fix it? I really appreciate it.
Spreciado is offline   Reply With Quote
Old 05-07-2016, 08:35 PM   #2
mduff's Avatar
Buttons outside are exposed under the skirting. We've had to replace both ours. When I replaced I applied dielectric grease which offers some protection. May install weatherproof boxes and mount switches inside those, which others have done.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 05-07-2016, 11:37 PM   #3
Stabilizer jacks 27rkss wildwood
Now the remote does not work.
Old 05-07-2016, 11:38 PM   #4
Or i mean the jacks no longer go down with remote and i can here clicking sound coming from under mid section of travel trailer.
Old 05-08-2016, 11:36 AM   #5
I was just testing my remote on our 2104 Wildcat Maxx, everything works except the front jacks and auto leveling. Like you, all I hear is the clicking coming from the control box. My jacks still work from the outside panel, just would be convenient if the remote worked!
atcla is offline   Reply With Quote
Old 05-08-2016, 11:58 AM   #6
rcla2014's Avatar
Is your unit plugged in to shore power? The clicking noise would lead me to believe that you have low DC power, i. e. Low battery power.
If not on shore power, plug it in. If shore power is not available, back up tow vehicle to the trailer and plug in to the tow vehicle. Then try again.
Maybe before that, test your battery with the BAT button on the monitor panel.
rcla2014 is offline   Reply With Quote
Old 05-08-2016, 10:40 PM   #7
Stormrider151's Avatar
Find yourLCI control board and check the fuses. It's a separate fuse block from the converter and could be located anywhere. May be around the water pump area (of all places). Mine did this and it was a blown fuse.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-09-2016, 01:00 PM   #8
Broadway Joe's Avatar
Open The panel under the stove, req's removing two screws. Thats the control panel staring at you.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 05-09-2016, 05:35 PM   #9
My jacks would behave this way, took the trailer in and they replaced the entire wiring harness and wireless control unit.
I have also had the pins fail that allow the jacks to lower/raise. have someone try the jacks while you are under looking to see if the jack screw mechanism is turning. if so the pins probably fell out or broke and fell out.
either way your looking at warranty work.
2015 FR Wildwood X-Lite 262BHXL
2007 F250 4wd CC SB 6.0 Diesel
5LowesOR is offline   Reply With Quote
jacks, wildwood
