Old 03-13-2014, 11:29 PM   #1
Wildwood 281QBXL Propane system
Was checking propane bottles and did not find any gauge or way to tell when propane bottle empty. Turned both bottles on prior to trip but do not know how much I have used. Any suggestions?
samsonib6 is offline   Reply With Quote
Old 03-14-2014, 03:03 AM   #2
Witch Doctor's Avatar
THey have all kinda of gadgets out there. Is anyone better then the other I don't know I bought a gage that go's in between the bottle and supply line. The problem I found is that it will fluxuate with temp more then the gas. The only true way to know is to weight the bottle. Some say pour hot water down the side and you will see the level, tried that to.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-14-2014, 06:53 AM   #3
5erDriver's Avatar
If your propane system has automatic changeover there should be a sight glass on there that tells you when the first one is empty. Likely is green dot when full that will be orange if empty. If its a simpler system then it will draw from both tanks equally if they are both open. Best to close one in this case and it will only draw from one. Therefore you know when one runs out and you can turn the other one on and refill.
2013 Sandpiper 365SAQ
2008 Ford F350 Super Duty
6.4L Powerstroke Long Bed CC
5erDriver is offline   Reply With Quote
Old 03-14-2014, 07:25 AM   #4
Engineer of Crazy Train
ChooChooMan74's Avatar
I occasionally look at my changeover. When I see it not green, turn the knob, and take the empty bottle to get filled.
Sent from my Samsung Note 8 Tablet using the FRF Android App!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-18-2014, 02:34 AM   #5
I have used this Shop Master Forge Metal Propane Gas Level Indicator at Lowes.com=
But they are not real accurate, they give a pressure reading which does fluctuate with the hot and cold not the actual level of gas that's in the cylinder. If you take the tank off and put it on a bathroom scale and empty 20lb cylinder should weigh around 18 pounds empty and 37-38 pounds full.
rccktmn2 is offline   Reply With Quote
Old 03-18-2014, 03:32 AM   #6
BamaBob's Avatar
X2 on the changeover system (if you are so equipped) this is the best course.
In the past, we have used one of these in0line gauges:
Amazon.com: Camco 59023 Propane Gauge/Leak Detector: Automotive
Gages are not that accurate -- more of a ballpark estimator. A auto changeover system is IMO best - you know the tank is empty and on the next supply run you can refill it.
Amazon has several ones in stock - I found this one for you to take a look at:
Marshall Excelsior MEGR-9984 2-Stage Automatic Regulator : Amazon.com : Automotive
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-18-2014, 07:25 AM   #7
Thank you. I am going to have the automatic switchover installed on my next visit to the RV repair shop.
propane, wildwood
