New camper this spring, and it's time to be winterized. Can anyone tell me where the pump is located and if I need to purchase the in line valve for adding anti freeze. It would be nice to pick up the parts I need while still in the city!
We've had two Wildwoods. In both cases the pump was close to the inlet for the fresh water tank; locate the inlet outside and check cabinets inside in that area, may be an access panel covering the pump. Both needed an adapter to add antifreeze.
