Old 04-10-2014, 10:23 PM   #1
Adony's Avatar
Wildwood Frame Preservation
For the past few years, the area of the I-Beam Frame just behind the 2 sets of rear tires on my TT has as showed signs of rusting and corrosion (area above grey / black tank dump valves). Each year I have power wire brushed this area, primed and repainted it. I am wondering that if this year it might be wise to clean and prep the rusting area and re-coat it with the spray on rubberized undercoating material that I have used on vehicles in the past?? I have find no where that anyone has done this in the past so I am seeking thoughts and / or opinions before I proceed. Help??
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 04-10-2014, 11:08 PM   #2
Oklahoma Proud
MillerTime's Avatar
Go for it. Clean rust area again, apply an acid etch primer lightly to bare metal. Add a coat of primer/sealer and let flash (or dry to recomended time) then top coat with paint. After paint has cured spray your rubberized undercoat on and your golden.
I usually spray industrial enamel on trailers and flatbeds and truck frames. Its super tough and durable, but it will rock chip after a while.
The undercoat helps to cushion the rock impacts- just be prepared, its expensive, probably close to $20 a can for big cans of good stuff & you will probably need 6+ cans. A newer crew cab truck frame (bare with nothing on it) will take 3 cans that are applied rather lightly.
Best of luck!
MillerTime- Future Sabre Handler!!
frame, wildwood
