Correct, you have the bottom valve open allowing water into the water heater.... and the top one turned so it is allowing water out of the heater into the hot water line. (thereby closing off the crossover).
You are good to go for camping.
To bypass the water heater, you would close off the cold water to the heater intake, and then close off the hot water output from the tank, which at the same time opens up the crossover to allow antifreeze to be placed into the cold water line and crossed ove into the hot water line. The valve also would be closing off the line connected to the water heater hot water output, thus keeping antifreeze from backfilling the tank.
2011 Flagstaff 831 RLBSS
