Old 11-04-2018, 11:22 AM   #1
Smk
Winterize my travel trailer
I have a Forest river wildwood 28ckds and was wondering how to winterize the trailer using the pink anti freeze do I put the stuff in the fresh water tank and let the water pump it thru or is there some other way that I don't know about?
Smk is offline   Reply With Quote
Old 11-04-2018, 11:31 AM   #2
does your unit have a pick up tube/straw at the docking station? mine does. short tube with a cap that can be removed and draws anti freeze from jug straight to pump
Kimber45 is online now   Reply With Quote
Old 11-04-2018, 11:34 AM   #3
Smk
No has no docking station for that
Old 11-04-2018, 11:35 AM   #4
Hugeez's Avatar
I’m not exactly sure about your model but you don’t want it in your fresh water. It will take forever to get that rinsed out. Should be a hose with a shut off valve attached to your water pump. First you want to find your low point drains, if you have them and drain them out. Be sure to open all the water knobs inside so the water can drain. Shut off all the knobs afterwards. Find the hose on your water pump and stick it in the jug of antifreeze. Turn your water pump on and let the pump fill and the pump should stop pumping. Make sure you bypass your water heater. Go around to each faucet and open til the pink comes out. Don’t forget your outside sink and shower if you have one. Do the toilet and inside shower too. Pour some pink down the drains so the traps fill. Dump the rest down the drains and into the black water tank via the toilet. I’m sure others will have their own way of wintering. You will figure out what works best for you.
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
9 nights camped so far in 2018
Hugeez is offline   Reply With Quote
Old 11-04-2018, 11:40 AM   #5
Smk
I will have to find that , thanks for the info
Old 11-04-2018, 11:43 AM   #6
Hugeez's Avatar
Pump should be in the area above the fill for your fresh water. I had flip the switch for the pump a few times to hear where it was hiding.
2018 PUMA 31 BHSS
E2 WDH
USN 86-92
Old 11-04-2018, 12:53 PM   #7
Winterizing RV
Check out this link: https://www.google.com/search?q=wint...hrome&ie=UTF-8
Rmstack is offline   Reply With Quote
Old 11-04-2018, 12:53 PM   #8
Pockets
Check to see if you have an antifreeze port beside the city water
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(10 nights)
Pockets is offline   Reply With Quote
Old 11-04-2018, 01:17 PM   #9
Smk
Saw that video but I dont that kind of set up mine is just basic set up. I only have a city water connection and a water and fresh water connection no place so there must be a hose somewhere that I can do this just have to find it, thanks
Old 11-04-2018, 02:04 PM   #10
What I do and have done in Indiana where it can get below zero in the winter. I drain water heater and all tanks. Bypass water heater. Using compressor set to 30 lbs. Place compressor on city water input. Blow out water lines by turning on the kitchen faucet, bathroom faucet, shower, shower and low water drains one at a time until no water comes out of each one. Pour 2 cups of anti freeze down each drain and toilet. Much easier to un-winterize in the spring or if I desire to camping before spring and want to winterize again because of no anti freeze in the lines. I made an adapter between compressor and city water hook up so that I don't have to go outside and turn compressor on and off. I just turn faucet on and off to build up pressure to blow out the line while leaving compressor on. I have done it this way with 4 RV's and 20 years with no problems.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
trailer, travel, travel trailer, winter, winterize
