Old 11-10-2014, 07:57 PM   #1
Winterizing 26tbss Wildwood
Hi folks,
I'm new here and new to RVing. Just bought a 2015 26TBSS Wildwood and was wondering what the hose is that goes into a anti freeze jug? Is it a normal garden hose cut off? Thanks so much!
phardage is offline   Reply With Quote
Old 11-10-2014, 08:59 PM   #2
mduff's Avatar
I disconnect the input to the water pump and connect a hose and insert the other end into the AF. The connection at the water pump is smaller than a garden hose. I picked up a length of clear pipe, and the appropriate connector at an RV shop. After releasing the low point drains to clear out the water, I close them and turn on the water pump which pulls AF into the lines.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 11-11-2014, 07:45 PM   #3
Bryce's Avatar
Get one of these kits. Camco winterizing kit.
Our '07 takes less than 2 gallons of pink stuff.
Bypass the hot water heater and dump it. Pump pink stuff through everything inc backwards out the city water connection. Dump all the tanks (fresh, black and gray)
'01 F-250 PSD CC 4x4 SB
'08 Wildwood LE 26TBSS
State's we've RVed in
Bryce is offline   Reply With Quote
Old 12-06-2014, 12:42 PM   #4
jaba1974's Avatar
I have a wildwood 26tbss 2014 model. I just had one of these Camco winterizing kits installed and did the winterizing myself. Also removed the battery to store in the garage for the winter.
jaba1974 is offline   Reply With Quote
Old 02-15-2015, 12:29 PM   #5
RVer
shanbub4's Avatar
I don't use anti freeze. I got a air compressor and hook a hose to the water connection and open the hot water heater blow 50 psi through until all water is out. Open all faucets. I have never had a problem.
shanbub4 is offline   Reply With Quote
26tbss, wildwood, winter, winterize
