Old 08-22-2019, 06:49 PM   #1
jcompton0001's Avatar
Winterizing my 2020 - 26dbud
Where is my bypass valves on my 26dbud. Actually where is my fresh water pump?
I canít find any instructions for winterizing this thing.
jcompton0001 is offline   Reply With Quote
Old 08-22-2019, 06:58 PM   #2
The Dude Abides
HouseClark's Avatar
Not sure about your model, seems to me the water pump is always near the fresh water intake on outside of camper. Maybe start there?
HouseClark is offline   Reply With Quote
Old 08-23-2019, 01:27 AM   #3
Iíll look again but the furnace and refrigerator is in this area and I canít find a panel to remove to find the pump. I always use RV antifreeze and put it through the fresh water pump on all my other campers in the past.
Old 08-23-2019, 06:47 AM   #4
The Dude Abides
HouseClark's Avatar
Did you look under the bottom bunk? Mine was not super easy to lift up until after I did get the plywood up I drilled a finger hole for easier access.
Old 08-23-2019, 06:51 AM   #5
The Dude Abides
HouseClark's Avatar
My water pump was hidden under the sink on the floor... I had to remove two screws to access.
Old 08-23-2019, 03:17 PM   #6
My pump is below the panty cabinet next to the bathroom
moony is offline   Reply With Quote
Old 08-24-2019, 06:28 AM   #7
How did you get to it
Old 08-26-2019, 07:18 AM   #8
Camper
Different model but mine is located under the fridge right next to the water tank fill line.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 08-26-2019, 07:21 AM   #9
By-pass is usually located on WH...at least on a lot of newer models. Put water in tank, open faucet, turn on pump, follow the sound.
TheWolfPaq82 is offline   Reply With Quote
Old 10-30-2019, 09:01 AM   #10
About to winterize a 2019 Salem 26 DBUD. Is there a hose attachment to place into the anti-freeze? Pump is located in pantry: lower level.
Thanks!
Tablerock Lake is offline   Reply With Quote
Old 10-30-2019, 09:44 AM   #11
MillMitch's Avatar
I have a Grey Wolf not a Salem, so couple thoughts. Assuming you don't have a winterize connection on the outside of the TT, then look for a bypass valve on the intake line going into the water pump. Probably close to the screen. If your TT doesn't have one, you'll need to install one.
Good luck.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 10-30-2019, 12:35 PM   #12
Thank you sir for the information.
winter
