I have a 2017 Wildwood T263BHXL. I am trying to winterize it myself since I was encouraged on how easy is was... LOL!! I am not able to find the water pump and not sure where else to look. Does anyone know if it has a winterize bypass or if I need to buy a pump to do that. Why isn't it as easy as they show in the videos?? Please help... Thanks!!
Drain the fresh water tank. Then open the faucets and turn the pump on for 15-30 seconds. That will clear the pump. I use an adapter to flush the lines with compressed air (less than 50psi) after I've drained them. If you have an installed filter, empty that, and leave the bowl off.
To find the water pump, turn it on with a faucet open. Then listen around to find where the sound is coming from. Mine is in the front storage bin, behind a sliding panel.
