Make sure you have some room above the tank, between it and the floor. They have to give a little somewhere, just not enough to bend up things or fall out. If you restrict the ballooning too much on the bottom or sides it will balloon up on the top and you do not want to see what happens if the tank is too close to the underside of the floor. I seen one lift part of the plywood floor off a popups frame once.
