Old 03-22-2012, 09:52 AM   #1
Left Turn Signal
Just picked up a used 2010 WPT30WR, and the left turn signal isn't working. I opened the conduit box under the tongue, and the yellow wire from the hitch plug is capped off and not hooked up to anything. There are also no disconnected wires coming from the trailer side that I could find. Does anyone know what color the left turn signal wire is on the trailer side?
tracetrimble is offline   Reply With Quote
Old 03-22-2012, 09:56 AM   #2
Herk7769's Avatar
The colors may be unreliable.
Here is the pin out for the connector and what I use to keep em clean.
Name:	Connector Pin Out.gif
HAM CALLSIGN - KC3FFW
Old 03-22-2012, 11:00 AM   #3
Did you try a new bulb? Sometimes you have to plug and unplug the trailer connector from the TV connector a few times to get a good connection. If that doesn't fix it I would use a multimeter to check the connection on the TV for power. If it's good then check bulb socket on the trailer for power.
Len & Cheri is offline   Reply With Quote
Old 03-22-2012, 11:11 AM   #4
Pirate Todd and Wench
I use a dental pick to clean up the contacts, then coat them with "electrolytic" grease for protection from moisture. Making sure all that is good...then on to the multi meter! Your wiring is most likely fine, look for the obvious...be the bulb! lol
-Todd and Sherri
-2006 F250 Super Duty King ranch Diesel
-2012 Windjammer 3008w
-Equilzer 1200lb hitch
mrtodds is offline   Reply With Quote
Old 03-22-2012, 01:48 PM   #5
Herk7769's Avatar
Just an FYI. My camper's tailgate light bulbs are corroded into the sockets and can't be removed without breaking them. They still work, but I carry the replacement tail light assemblies in the camper for when they don't.
Old 03-22-2012, 03:22 PM   #6
okdrifter's Avatar
Maybe blown fuse on tow vec.
Doug and Carmin
2010 Wildcat 31TS
2008 F-250 King Ranch
okdrifter is offline   Reply With Quote
Old 03-22-2012, 04:01 PM   #7
Herk7769's Avatar
This is a good point. Does the left parking light work with the lights on?
The same truck fuse works both the left turn signal and the left tail/parking light.
Old 03-22-2012, 06:33 PM   #8
buffalohunter's Avatar
OK, got to know Lou, where can I get the cleaning tool?
2012 Rockwood Windjammer 3008 W
2007 Tundra Reg Cab 4X4 SR5 5.7L
buffalohunter is online now   Reply With Quote
Old 03-22-2012, 08:05 PM   #9
Herk7769's Avatar
Phillips - 6 & 7 Way Plug & Socket Brush
6 or 7 pin are available
Old 03-22-2012, 08:43 PM   #10
TURBS's Avatar
on newer trucks and his may fall into that category. the trailer stop turn tail fuses are separate from tv. so if theres a short in the tt the tv still works ok .
