Old 03-25-2014, 10:05 PM   #1
mattress replacement
Any body every replace the mattress in the drop down bed on a 21vfb? The mattress on there, in my opinion sucks. I put a memory foam under it and that helped a little but still feel like I'm lying on the damn frame every time I sleep. We are looking for an affordable replacement.
skydiverchuck is offline   Reply With Quote
Old 03-25-2014, 10:09 PM   #2
KDHfan's Avatar
Thicker memory foam. If a memory foam won't work for you, I think you'll be hard pressed to find a mattress that will do more. I'm pretty sure Stearns & Foster doesn't make RV matresses... Lol.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 03-25-2014, 10:10 PM   #3
KDHfan's Avatar
Oh wait... Why would you put the memory foam UNDER the mattress? Put it on top.
Old 03-25-2014, 11:36 PM   #4
Fulltime family RVer
We added foam mattresses to our bunks- what was there originally was about 2 1/2" thick and didn't support adults whatsoever.
I ordered 4" foam from www.foambymail.com in custom sizes. I was comfortable with just the foam laying on the floor. We don't have height issues, so I just put them under the original mattresses.
I'm also confused why you're putting the topper under the mattress?
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
ependydad is online now   Reply With Quote
Old 02-14-2017, 07:47 PM   #5
I put memory 3" foam on top, did not help much. Going to put 1/2" plywood in the frame and screw it down then put the mattress's back down. Should improve it a lot.
Tampa Dave is offline   Reply With Quote
Old 02-15-2017, 06:53 AM   #6
The Newsoms's Avatar
We just use a memory foam (3in) and no mattress. It works great for us and my husband is a picky sleeper.
Jimmy & Teresa Newsom
Now:2016 Cardinal 3825FL/2012 Work and Play 18EC
Then: 2010 Fleetwood Discovery 40X
2012 Ford F-250
The Newsoms is offline   Reply With Quote
Old 04-22-2017, 06:03 PM   #7
We put our spare Sleep Number bed in ours. World of a difference.
sstuner is offline   Reply With Quote
replacement
