Hello UHCREWDOG, and WELCOME. I have a Work and Play 18LT, and have checked the walls for a TV mount. While the information above on studs is good info, my 18LT has solid 3/4 inch plywood walls, no studs. You can check for this at he side vents in the garage area. Look at the vents closely and and you an see where the plywood is cut, and measure the thickness. Just be careful and don't run a screw through the trailer. I called Forest River and got some screws designed to be run all the way through to mount my TV with. Hope this helps. Toy haulers are a little different.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
