Old 09-27-2015, 10:13 PM   #1
Towing new 18ec
We just purchased a 2013 18ec. Took it out for the first time last weekend and really enjoyed oursleves. We ride 4 wheelers quite a bit from the fall through spring and the 18ec seems to be exactly what we need.
I'm pulling it with my 2011 F150 using a weight distribution hitch and a sway bar. The truck pulls with no problems but the rear sqaut is a bit more than I would like. At times it feels like the trucks suspension is a bit overwhelmed. Has anyone else experienced a similar issue? Have you added any suspension upgrades? Thanks for any input.
Mike2013 is offline   Reply With Quote
Old 09-28-2015, 07:39 AM   #2
AlR
I have a 2013 18EC as well. I use a 2013 Gmc 2500 Duramax to tow. It has no prob towing the trailer using a WD hitch I had laying around. I put Firestone ride-rite airbags in so I could adjust the rear truck height alittle. Love those air bags.
2013 GMC 2500 Duramax
- Ride-Rite airbags
2013 Work n Play 18EC
AlR is offline   Reply With Quote
Old 09-28-2015, 08:36 AM   #3
jimmymjr's Avatar
I pull my 27RKSS at around 8000 lbs or so with a stock F150 with no sagging at all. You might need to adjust the WD a little. I use a Blue Ox WD chain type hitch I took it up one link and it leveled it out. Now it pulls almost like it's not back there.
jimmymjr is offline   Reply With Quote
Old 09-28-2015, 11:04 AM   #4
Have you checked the tongue weight on it? Work and Plays have a lot of tongue weight. You may be as high as 1500 lbs and not realize it and or your weight distribution bars might be too light.
2015 Work and Play 30WRS
2005 Dodge Ram 2500 4x4 diesel
wildbill79 is offline   Reply With Quote
Old 09-28-2015, 11:29 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
Sounds like trailer improperly loaded plus improper WDH. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped so far 2017 62
Old 09-28-2015, 08:33 PM   #6
Thanks for all the feedback. I'm sure the issue isn't a improperly loaded trailer because the sag occurs even when the trailer is empty. However, I discovered today the TW is 1,163 (I thought it was closer to 850) and my WDH says it's rated to 1,000. I'm checking on new, higher capacity spring bars for the hitch.
I'm also thinking about adding either air bags or a Roadmaster Active Suspension to the truck. Right now I'm leaning toward the RAS. Any thoughts?
Old 09-29-2015, 07:20 AM   #7
If 1163 lbs. is the number your got off the website or a brochure you may want to wait on getting spring bars until you actually weigh your rig loaded at the scales or use a sherline tongue weight scale. The numbers could be drastically different depending on your trailer options, how you have it loaded, batteries, generator, water etc...
Old 09-29-2015, 08:34 PM   #8
good idea, thanks
Old 10-28-2015, 11:27 PM   #9
Air bags in the back will sole this problem and give you a level and better ride.
Jack
jaherbst is offline   Reply With Quote
Old 10-29-2015, 11:26 AM   #10
Thanks, I went with the Roadmaster Active Suspension.
towing
