Old 08-23-2013, 07:19 PM   #1
itch'n to road trip
campnqueen's Avatar
Work & Play 25 ULS water heater bypass valve
Ok... so last week we picked up our NEW Work & Play 25 ULA.
There are three things that our dealer could not figure out or find.
1.) We are looking for the water heater bypass vavle. We have a 10 gallon water heater.
2.) The fresh water dump valve/ low point for fresh water tank. Dealer told me quote " Its under there somewhere"
3.) And inside the door next to the refridge there are three light switches.
1-for outside bug light
1-for the inside ceiling lights
1- and one... who knows? cant figure it out... Anyone have a clue?
Yes we have heated tank... switch is across the way, next to the sink.
Along with the water heater switches.
Your help in this matter is greatly appreciated.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 08-23-2013, 09:59 PM   #2
Dave_Monica's Avatar
You'll have to access the back of the WH and look for a 3 valve arrangement on the supply/discharge lines. May only be 2 valves if they used 3 way valves.
Both low point drains and FW tank drain are usually quite obvious and reachable somewhere on the perimeter under the camper.
No clue there!
Dave
Old 08-25-2013, 06:29 PM   #3
itch'n to road trip
campnqueen's Avatar
Ok... here is what I have found...
looked under the bathroom sink in the cabinet. The photo is of a pipe with what looks like a knob of some kind on top.
Jasper Ga.
Old 08-25-2013, 06:34 PM   #4
fonzie's Avatar
This photo is for your black tank flusher, it is a vacuum break to prevent water to flow back.....
Fonzie
Old 08-25-2013, 06:35 PM   #5
wmtire's Avatar
As Dave pointed out, the valves are beside the water heater. Where exactly is your water heater located at. We talked about it in a few forums this morning on how to find the valve(s):
Where's the Hot Water Bypass?
2011 Flagstaff 831 RLBSS
Ducks are just all-terrain chickens
Old 08-25-2013, 06:48 PM   #6
itch'n to road trip
campnqueen's Avatar
Fonzi... you are kidding? HHhmmmmmm? would have NEVER figured that one out. The black tank flush IS on the outside skin somewhere near that thingy.
Thanks for the info. Any clue on water heater bypass cut off valve?
Jasper Ga.
Old 08-25-2013, 06:49 PM   #7
itch'n to road trip
campnqueen's Avatar
Or how about one of these switches... the one on the far right... can NOT figure out what it goes to.
Jasper Ga.
Old 08-25-2013, 10:26 PM   #8
As mentioned, the bypass valve will be on the back of the water heater. You'll probably have to remove a panel inside a lower cabinet to access the back of the WH.
The light switches you show are 12V and most likely for lighting. If it's not for interior lights, check it it's for the exterior porch light, step, or scare light.
Dave
Old 08-26-2013, 10:27 AM   #9
Try under the bed , my water heater is on the bedroom wall. Remove the mattress, up towards the head of the bed under where the mattress was should be a panel. The under bed storage is smaller than the mattress size.
At least this is how mine is ...201- W & P 25 ULA ......
As far as the switch........power awning ????? ..... I got nothing
Foneguy is offline   Reply With Quote
Old 08-29-2013, 08:59 PM   #10
itch'n to road trip
campnqueen's Avatar
Fone guy.... well that would be close to where our water heater is.... I will have to look... what a pain is the ***** if that IS where it is. will keep you posted.
Jasper Ga.
heater, water, water heater
