Old 04-09-2008, 06:30 AM   #1
13.5K vs. 15K AC unit
I am getting ready to order an 831KRSS was wondering if there are any disadvantages getting the larger AC unit. I will be doing most of my camping in South Florida so it seems like a no brainer, but I would appreciate any input.
madkaw71 is offline   Reply With Quote
Old 04-09-2008, 06:32 AM   #2
Welcome to FRF!
Hmmmmmmmmm........... South Florida?? Bigger A/C sounds better to me.
aintgotnun is offline   Reply With Quote
Old 04-09-2008, 10:17 AM   #3
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
welcome....go large!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 04-09-2008, 10:44 AM   #4
Head Rambler
My GS-280 has the 15K ducted and here in the south during the hottest part of the summer we're glad it does. I wouldn't even consider the smaller unit on the 831krss.
Gotta go campin!
Old 04-09-2008, 01:10 PM   #5
Do you self a favor, go big. I just had a 13.5 Dometic and it is useless. I had a Carrier 15k installed, there is more air flow and not as load. Air flow is based on CFM's. I have an 8314 ss TT.
Old 04-09-2008, 06:23 PM   #6
I agree,
GO BIG! I too had the 13.5 on my last trailer. Did not cool down enough. If you are camping in Florida (my wife's home state) you will want the 15K AC.
OREGONCAMPER
2008 Rockwood 8317SS - 2010 F150
2013 Camping Days: 22
2012 89 2011 50 2010 61
OregonCamper's Pics click here
OregonCamper is offline   Reply With Quote
Old 04-09-2008, 06:23 PM   #7
Thanks for all the input...I'm ordering the TT in the morning with the 15K.
Old 04-23-2008, 07:37 AM   #8
toshiba's Avatar
yes go with the bigger A/C... not much difference in cost.
Living the good life Rving and enjoying it .
irv2.com National rally... Dundee, Ohio
June14-20, 2009
toshiba is offline   Reply With Quote
Old 07-15-2008, 09:58 PM   #9
I just purchased a 831 Flagstaff which comes with a 13.5 btu ac unit. I thought I would need a bigger unit since this was a 31 footer and I too live in south Florida. I went to the keys on July 4th weekend and can't expect it to get any hotter in the country unless I travel to death valley and I must say, I had the ac unit set on 70 and woke up freezing. I thought about getting the larger unit but after that weekend, there will be no need for that. I think its always a good idea to have a larger unit so that a smaller one won't work as hard, but since the one that came with the camper was a 13.5, no reason to go higher. Save your money for fuel because all I was getting was 7 to 8 mpg with my Dodge ramm hemi 5.7
Duffman79 is offline   Reply With Quote
Old 07-16-2008, 04:24 AM   #10
I am glade to hear you are satisfied with your 13.5. When the sun go's down and everything starts to cool off the heat load is reduced on an RV, then the A/C can keep up with demand. For every person in your camper by day that is moving around they are producing approx 400 BTU's each along with a TV that is on a microwave or any other heat producing equipment that my be on adds to the load, then factor in the sun and heat load from the out side. The hottest time of the day is approx 5:00 pm in the Summer time, so the A/C system has some work to do. At night everyone is a sleep and body temps drop, no heat producing equipment is on and the TV is off and the heat load is reduced on the out side of the camper because the sun is gone. Hot air moves to cold, so when you remove heat from in side a box ( camper) all that heat from the out side is trying to get in side. So I suggest in very hot climates, add curtains to the windows, install some kind of insulation in the sky lights and set the fan control for the A/C to ON so that air keeps moving and reduces hot spots in the camper and most important keep the Filter clean.
Old 07-16-2008, 11:23 AM   #11
SSport's Avatar
Send a message via Yahoo to SSport
I have a 40 foot cherokee and have the 13.5k unit ducted. It was well over 90 degrees this passed Saturday and my fiance had it FREEZING in there....lol
SSport is offline   Reply With Quote
Old 07-17-2008, 12:58 PM   #12
Just woundering, how many slide outs do you have on your 40' footer? and here I thought 34' was big
Old 07-28-2008, 03:24 PM   #13
SSport's Avatar
I have two. There was an option for a 3rd but didn't want a front slide out cutting into my deck space....lol
Old 07-28-2008, 04:33 PM   #14
Cyber Phrenologist
Radio's Avatar
And while you're at it: (regardless which AC you get)
Get the tinted windows.
When you get the unit home go around and plug all the drafty places with "great stuff" or some other type of sealant.
Get some of those sponge pillows that you stuff up into the overhead vents.
Enjoy!
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 07-28-2008, 08:25 PM   #15
Grape Escape
And don't run fantastic fan with air on. Last weekend I could not understand where all the cold air was going. After turning off bath fan it cooled in no time. Must have sucked cold air out as fast as it went in.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 07-28-2008, 08:29 PM   #16
Originally Posted by radio View Post
and while you're at it: (regardless which ac you get)
get the tinted windows.
Enjoy!
yes, that is another good suggestion. There is a list of things to help reduce the heat load.
Old 06-19-2019, 12:59 AM   #17
KAISOR's Avatar
ID:	207745Get 14 Mpg pulling my 33 ft fifth wheeler. 2018 Cummins 6.7
KAISOR is offline   Reply With Quote
Old 06-19-2019, 01:02 AM   #18
KAISOR's Avatar
Originally Posted by KAISOR View Post
Attachment 207745Get 14 Mpg pulling my 33 ft fifth wheeler. 2018 Cummins 6.7
flagstaff
