Old 10-02-2015, 07:41 PM   #11
Originally Posted by A32Deuce View Post
Micro clock is 115. Everything else you said is 12volt. Bat switch was on?
Yes I found the battery disconnect. It works so much as to make it so the tongue back works or doesn't so that part seems to fine. Could there be some fuse I've blown inside that prevents juice from batteries powering these things?
jlindo is offline   Reply With Quote
Old 10-02-2015, 08:54 PM   #12
A32Deuce's Avatar
k the maxi fuses at the converter. That is protected so they blow if bat hooked up backwards and feed side. Big in size.
A32Deuce is online now   Reply With Quote
Old 10-02-2015, 11:27 PM   #13
Thanks, I'll check this in the morning! It's going to be a warranty thing in the end but I'd still like to understand why/how it happened.
2016 Flagstaff 27 BEWS
2015 Ford F-150 XLT EcoBoost
Old 10-04-2015, 01:15 AM   #14
No go so far...I've checked all of the standard breakers and all good there seemingly. Also the same with the 40 amp fuses. Is there some other place to check fuses (inline or something) that I'm not aware of? How would the tongue jack work on battery...is it wired separately perhaps? Somehow still to the disconnect but still separate from the inside stuff?
Old 10-07-2015, 03:08 PM   #15
hawki8624's Avatar
My tongue jack is wired directly to battery so it is not affected by the battery disconect switch which is wired in after the battery.
hawki8624 is offline   Reply With Quote
Old 10-11-2015, 07:33 PM   #16
So the final answer was a busted wiring connection/breaker that ran back from the battery disconnect to the converter/inverter. So no power was even making it from the 12V side into that system to begin with. Looks like they yanked on the wiring harness there to get the second battery installed maybe. Thanks for all the advice from everyone!
snow
