Old 03-25-2015, 02:42 PM   #11
fonzie's Avatar
Do they work on shore power? Is your battery disconnect on?
Fonzie
Old 03-25-2015, 04:07 PM   #12
Brazealnut4's Avatar
I have it in storage with no access to shore power currently. The battery disconnect is connected and it has a full charge.
Mike
2015 Flagstaff 27RLWS Emerald Package
2013 Ford F150 STX 5.0 V8 3.55
Brazealnut4 is offline   Reply With Quote
Old 03-25-2015, 04:22 PM   #13
fonzie's Avatar
OK, as sometimes it is the mini-breaker underneath the trailer near tongue that is tripped and needs to be re-set (small black button) (when it works on shore power but not on battery alone)
Fonzie
Old 03-25-2015, 08:46 PM   #14
Slympicins's Avatar
Wow they are putting mini breakers on now? Nice. Just haven't replaced mine yet as I have a fist full of fuses. Been there done that before. Nothing like crawling under the a frame in a rainy day. What a bs place to put fuses.
By the way...there is a fuse under the a frame for the stab Jacks too. Like I said, I have a fist full of fuses. No idea why they blew out on me last year. Hasn't done it in a while. Maybe FR buys cheap Chinese fuses too.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
Old 03-29-2015, 06:05 PM   #15
Well the soft breaker reset didn't work. The black button was very "soft". It floated really. I couldn't get it to pop in or out. Any idea what that might mean?
Mike
Old 03-29-2015, 08:58 PM   #16
Slympicins's Avatar
No idea. I still have the old fuses.
Chuck and Joanne
Old 03-29-2015, 09:35 PM   #17
fonzie's Avatar
Most likely it is damaged. Time to pull out the multi-meter if you have one and start testing. Need to check for 12 + on either side of the mini-breaker to see if good or not.
Fonzie
Old 03-29-2015, 09:41 PM   #18
I still have the old fuses too. I was unaware of the soft fuse. I replaced the 20 fuse that was blown and they still do not work.
Mike
Old 03-29-2015, 10:03 PM   #19
Hi most likely the reset able overload is not tripled. The reason the overload is there is to protect the tt wiring from the battery to the trailer. The battery has a huge amount of amps available and will make the battery wire turn red hot if it shorts out to the tt frame and burn the unit down. If you were having trouble with this overload the 12 volts to the tt would be lost. No lights or power with the tt not plugged in to 110 volts shore power.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 04-03-2015, 01:13 PM   #20
Picked up the trailer from the dealer today after having the water heater fixed. They replaced the clamp with a compression joint. Hopefully that will remedy that.
As for the power stabilizer jacks. I'm almost too embarrassed to say what it was but in the interest of preventing this from happening to someone else... At the time I pulled the fuse and found it to be burnt I went outside and grabbed a spare fuse. When I returned there were two empty slots. I put the new fuse in a spare (unused) slot. I misread the labeling as it was stamped and off a bit. Thus they never worked. I didn't catch the labeling issue. Oh well the tech was very friendly about it and the lesson has been learned.
Both issues were repaired at no cost too.
Many thanks to all for your input!
Mike
