Old 04-25-2014, 06:33 PM   #1
2014 30wfkss worst pulling trailer ever
THIS IS UNDOUBTEDLY the worst pulling trailer I have ever owned. I pulled it home from the dealer and could not get over sixty MPH it sawed so bad it was scary. I went and bought a new Anderson sway hitch. I pulled it to the lake and it swayed so much it would push us off the road. I have a DuraMax 2500 diesel. I am sick of this trailer.
porter lizard is offline   Reply With Quote
Old 04-25-2014, 09:25 PM   #2
Slympicins's Avatar
Have your dealer check your axle alignment. If it's out of alignment it will bobble back and forth as the tracking is greatly offset. Check tire pressure on both your TT and your TW. Make sure the dealer installed your sway bars correctly as well. There are several issues that could cause the sway. A trailer is just a trailer and they all pull the same if properly setup. Failing any part of these issues could cause problems.
Good luck and keep us posted.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
Slympicins is offline   Reply With Quote
trailer, 2014
