Old 08-19-2017, 03:22 PM   #1
2017 Micro-lite21ds Battery Disconnect ?
Is there a battery disconnect switch on these trailers. Unable to find one.
bobgulch is offline   Reply With Quote
Old 08-19-2017, 04:51 PM   #2
thecamping5's Avatar
Did you look under the fridge, that's where our is on a micro lite 23lb
thecamping5 is offline   Reply With Quote
Old 08-19-2017, 04:51 PM   #3
backon4's Avatar
Under the propane tanks facing the battery box.
2017 Micro Lite 21DS
2018 Ford Expedition
backon4 is offline   Reply With Quote
Old 08-19-2017, 06:09 PM   #4
That's where mine is and in a most inconvenient position. If it hadn't been pointed out to me I probably never would have noticed it tucked in next to the electric tongue jack.
TitanMike is online now   Reply With Quote
Old 08-19-2017, 06:19 PM   #5
backon4's Avatar
I know this because I spent the day replacing it with a dual battery switch and added a second battery. A little tight but managed to get them both in on the tray. I just had to cut off the handles of the boxes where they touched in the center.
Old 08-19-2017, 06:26 PM   #6
Have you ever wondered if people at the factory go out of their way to mount things in very difficult places just to mess with the end user?
Old 08-20-2017, 01:28 PM   #7
Behind and under the propane tanks ! There it is alright. Thanks so much, I thought I had looked everywhere. Seems my dual 12volt batteries drain in a day or two and I need that switch to save them.
Old 09-07-2017, 02:03 PM   #8
Might need bigger batteries if your trying to run off the grid. I have a 2017 microlite 21DS and modded it to have 4 6v golf car batteries which provide 430ah of capacity. The house batteries I got from the dealer were some cheapie 45ah marine batteries. With my new setup I can run the whole trailer minus a/c and microwave, with propane and the battery bank for more than 7 days. That includes running the TV off inverter power in the evenings.
thecastle is offline   Reply With Quote
Old 09-07-2017, 02:42 PM   #9
bikendan's Avatar
It may be because owners complained about previous locations or they didn't want it in an obvious place to be messed with.
Old 09-14-2017, 01:45 PM   #10
Kasual Kamper
I like mine on the inside where I can see it.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
battery, battery disconnect, lite
