Old 09-28-2014, 11:59 AM   #11
Henboy, do you have a screw going into the floor support closest to the wall also?
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 09-28-2014, 08:13 PM   #12
Yes. The bracket is an inverted "U" with screw tabs at both ends. Note that the piece I welded to the top is bridged to allow the clamp to pass thru. This raised (1/4") piece also allows the motor case to clear the bracket, as the case is lower than the barrel.
Henboy is offline   Reply With Quote
Old 09-28-2014, 08:31 PM   #13
Thanks for the response. It's tough to tell by the pictures exactly what goes on where the clamp passes through. There is another piece welded on that makes contact with the motor case?
2013 Rockwood 2109S
Old 09-28-2014, 08:43 PM   #14
Yes, another piece from 1/8" stock, two 1/8 x 1 x 1 spacers each end, bridged in the middle, total 1/4" high.
The motor case is 1/4" lower than the barrel, so the added piece added clearance for the case and provided a place to pass thru the clamp.
The barrel rests on the the piece added to the top of the main bracket.
Old 09-29-2014, 04:15 AM   #15
Welcome to the real world. When you purchase a RV-TT things will go wrong just like buying a home. With a TT a lot depends on just WHO did the product installs on your trailer, new guy/experienced/ hung over... To date FR has stepped up and repaired each of my problems. FR has allowed Camping World to do the repairs and so far I've been happy. With your slide out, let the warranty cover it as that's what you paid for.
SPARKEY BOB
IBEW LU 613 Atlanta
Micro Lite 21 FBRS
Toyota Tundra
SparkeyBob is offline   Reply With Quote
Old 09-30-2014, 09:54 PM   #16
By the way, an aluminum floor strut is located right under the motor. You can see it to the left of the cut-out for the water lines going to the other side of the trailer. Nice spot to place the bracket screws.
I used sheet metal screws for the bracket similar to those found on the floor under the couch
slide, mount
